Latest: airmastertapes
Overall: 17133
Online Now [63]:
Visitors: 62
Today: 22522
Total: 106686724
Forums › The Car › 206 Problems › had my codes read
had my codes read
Go to page Previous  1, 2
mtempsch
PostPosted: Thu Jul 26, 2012 11:28 am Up
anton1989 wrote:
it says says passenger side, how will i know if its the seat or airbag in the dash?
No idea, the OBD stuff I'm very much in the dark on...
Silvermetallic 2004 206 RC
anton1989
PostPosted: Thu Jul 26, 2012 11:32 am Up
Trade Rating: +16
this is the stuff i used to read the codes by the way
anton1989
PostPosted: Thu Jul 26, 2012 11:33 am Up
Trade Rating: +16
ok mate, thanks anyway
PostPosted: Thu Jul 26, 2012 11:42 am Up
Where did you get the definitions from for the codes? Confused
anton1989
PostPosted: Thu Jul 26, 2012 11:47 am Up
Trade Rating: +16
from the above software
take it there wrong?
PostPosted: Thu Jul 26, 2012 11:48 am Up
Are you able to set it to PSA fault definition or is it generic? Usually uses GM when it's generic
anton1989
PostPosted: Thu Jul 26, 2012 11:55 am Up
Trade Rating: +16
have no clue Confused
the guy at the garage let me use it, told me what to do to read the codes and delete them and thats it?
PostPosted: Thu Jul 26, 2012 12:04 pm Up
P0100 - Mass Air Flow (MAF) Circuit Malfunction
P0571 - Brake Switch "A" Circuit malfunction
P1112 - Diesel high pressure monitoring function. Pressure lower than the minimum pressure. (leak).
P1519 - Engine coolant blower motor - supply circuit/earth circuit malfunction Wiring, engine coolant blower motor, ECM
P0221 - Throttle/Petal Position Sensor/Switch 'B' Circuit Range/Performance Problem
P0230 - Fuel Pump Primary (Control) Circuit Malfunction
P0110 - Intake Air Temperature Circuit Malfunction
P1108 - Fan high speed circuit. Open circuit or short circuit to earth.
MAF is more than likely fault, but you can check this by testing the wiring and reading the live data to see if it looks acceptable. This will correct P0100 and P0110
Check the condition of the fuel pump as well as checking for leaks on pipes and the drain plug of the fuel filter. Also check the fuel pump relay. This will correct P0230 and P1112
P0221 will more than likely go away once the Air and Fueling problems are rectified.
P0571 is a common code, don't worry about it. It can sometimes come up when you set off with your handbrake on.
Check the wiring on the fans, run actuator tests and see if the slow speed fan works. More than likely the relay or resistor has fallen foul to rust and corrotion
anton1989
PostPosted: Thu Jul 26, 2012 12:31 pm Up
Trade Rating: +16
thankss lee,
whats an actuator tests?
any thoughts on the airbag fault
what about p1519?
looks like a long weeknd ahead!
PostPosted: Thu Jul 26, 2012 12:36 pm Up
Actuator tests are turning on equipment like the fan using your diag tool.
P1519 is the fan one that I talked about at the end.
Airbag - fitted a aftermarket head unit recently?
anton1989
PostPosted: Thu Jul 26, 2012 12:40 pm Up
Trade Rating: +16
yes and 180 seats, have i pulled somthing out?
i thought so i tried to run this test when i was there didnt work, heard a click sound though?
PostPosted: Thu Jul 26, 2012 12:43 pm Up
Check the connections under the seat, and also check the passengers airbag wire that runs across the cross-member behind the head unit.
Probably the relay/resistor that's corroded and failed - common
anton1989
PostPosted: Thu Jul 26, 2012 1:04 pm Up
Trade Rating: +16
checked the wire under the seats, can not see any splits or nothing, will check the wire behind the h/u at the weekend, am i just looking for splits? if i can not see nothing what else can i do ?
yes saw a few threads about the resistor will start there i think
apart from the airbagand cooling fan are any of these problems major?
PostPosted: Thu Jul 26, 2012 2:53 pm Up
Check the actual connections on the plugs too.
The MAF could cause the car to go into limp mode
anton1989
PostPosted: Mon Jul 30, 2012 1:19 pm Up
Trade Rating: +16
airbag light sorted, connection under sear was broke, couldnt see untill took apart
just the rest to go!
Page 2 of 2
