Online Now [430]:
Visitors: 430
Today: 58183
Total: 143367118
Forums › The Car › 206 Problems › Noise?
Noise?
tee_lad
PostPosted: Thu Jul 26, 2012 11:02 am Up
Got a noise that I don't recognise Confused Confused Its coming from the rear nearside of the car.
When I go over a speed hump or down a small bump it makes kind of a metal on metal noise for a split second. Problem is it doesn't do it all the time.
If I go over a larger bump or speed hump nothing happens and it only happens about 1 in 10. If I rock the car I hear nothing either. Any ideas what it could be so I can take a closer look Question Cheers Wink
anton1989
PostPosted: Thu Jul 26, 2012 11:06 am Up
Trade Rating: +16
does it sound like its inside the car or outside?
Andy180
PostPosted: Thu Jul 26, 2012 11:37 am Up
Spare wheel cage may be loose you could also check the exhaust and the rear shocks see if one of thems come loose worse case scenario the rear axle is shagged.
GTI 180
DanT
PostPosted: Thu Jul 26, 2012 12:21 pm Up
Spare wheel cage? Arb end plate loose?
tee_lad
PostPosted: Fri Jul 27, 2012 10:02 am Up
Outside the car Confused
tee_lad
PostPosted: Fri Jul 27, 2012 10:05 am Up
I'll take a look at this as the spare wheel was just in the boot when I bought the car, not even sure if there is a cage on my GTi Confused But this is a good possibility thx
tee_lad
PostPosted: Fri Jul 27, 2012 10:08 am Up
How do I check the rear shocks or do you mean a loose nut or something Question cheers ps hope its not the axle, changed one before and it was a nightmare.
MisterMagoo27
PostPosted: Sat Jul 28, 2012 4:44 am Up
This happened with my old pug. Turned out that it was the spare wheel cage. I didnt have a spare wheel in it, so it was light and kept bumping when I went over bumps. Really done my tits in as it kept falling open and dragging on the road lol
