Latest: tbafonso
Overall: 17130
Online Now [103]:
Visitors: 102
Today: 16876
Total: 104141649
Forums › The Car › 206 Talk › Peugeot Planet 2000 Info (Lee,Mr.BSI)
PostPosted: Thu Jul 26, 2012 3:30 pm Up
Ive just got a hold of this from ebay, which to all intents has worked(read my fault codes) but i know i can use it to activate things. For instance, if i wanted to activate auto locking, how would i do that?
Also, i have 2 faults, if i try to clear them, it says error, any ideas? I also noticed there is a 40 limit on error codes, what happens when you hit that?
PostPosted: Thu Jul 26, 2012 3:33 pm Up
Yes you can activate items, bsi configuration.
PostPosted: Thu Jul 26, 2012 3:35 pm Up
BSI > Configuration > Customer options > Locking and Openings
If you reach 40 then the memory is full and you can never clear fault codes again. So if it's in limp mode, it will stay in limp mode for ever. You have to get the eeprom cleared or get a new ECU, both cost around the same.
If it says error....engine running or not?
PostPosted: Thu Jul 26, 2012 3:39 pm Up
Engine wasnt running, ill check again tomorow. Better keep an eye on my clears then!
Also how can i check paramters, im interested in the 02 sensors, and fueling.Thanks for the info.
PostPosted: Thu Jul 26, 2012 3:42 pm Up
China clone doesn't always let you view graphic parameters
Test by ECU > EDC15 > Parameters > Air and Fuel
PostPosted: Thu Jul 26, 2012 3:44 pm Up
Yeah its a bit dodgy! Ebay Best! What version do you run?
PostPosted: Thu Jul 26, 2012 3:45 pm Up
Original
All up for sale in a week or so. Someone has already enquired about it.
PostPosted: Thu Jul 26, 2012 3:47 pm Up
Oh thought you had a HDi, not GTi.
So it will be IAW or S2000 not EDC15
PostPosted: Fri Jul 27, 2012 2:23 pm Up
Have been out to have a play tonight, activated the auto locking! I cant clear my codes though, is this because it is a clone? Also, how can i find out my ECU? I dont have the parameter option either ECU>IAW or S2000 doesnt show.
anton1989
PostPosted: Fri Jul 27, 2012 2:37 pm Up
Trade Rating: +16
whats this 40 limit on code clearing? is that just with peugeot plannet?
PostPosted: Fri Jul 27, 2012 2:55 pm Up
each time you clear the fault code the ecu will log the history; up to 40 times. after the limit you can no longer clear the fault code.
have seen so many time people need to bin the ecu because of this
anton1989
PostPosted: Fri Jul 27, 2012 3:00 pm Up
Trade Rating: +16
not good, never new this, been clearing codes the last 2 days,, cleared 7, 5 came back cleared them then they came back, i need to just fix the problem lol
so how do i know how many codes i have cleared? why is there a limit? bit rubbish if the privious owner has had some cleared also
can this not be reset before the limit has reached?
PostPosted: Fri Jul 27, 2012 5:06 pm Up
It also helps teach dicks who don't know what they are doing a lesson!
I think its hilarious when they can't start their car or it wont go over 30mph
anton1989
PostPosted: Fri Jul 27, 2012 5:11 pm Up
Trade Rating: +16
spose but as I said what if you bought a car not knowing sum1 had been clearing them?
How can I find out how many I have left?
PostPosted: Fri Jul 27, 2012 5:12 pm Up
it has been mention above. PP2000 can check the history
