Latest: Kifi69
Overall: 17183
Online Now [524]:
Visitors: 523
Today: 169708
Total: 143829766
Forums › The Car › 206 Problems › 206 running on carbs.... need help on what to do!
the.drewsta82
PostPosted: Wed Aug 01, 2012 7:18 pm Up
Well basically i know some of you will poo poo the idea of running Carbs but they sound so god dam sexy i want some.i am bidding on a set of Honda cbr 900 rr fireblade Carbs, i know where to get the manifold from but how would i.go.about getting it all.set up? Wat about the ecu, timing, will it have to go on a rolling road? Also silly question but will it still need a air.box??? loads of questions but some one out these knows. inbox me if you want to have a proper chat anxious talk me out of it lol
sedrew
PostPosted: Thu Aug 02, 2012 2:02 am Up
It's hardly a 206 problem until you start trying to fit them.
The car is controlled by the ECU which tells the injectors to deliver the correct amount of fuel into the cylinder. Start messing with the injectors and the engine won't start and then it will be a 206 problem.
Unless you have an in depth knowledge of the IC engine (which reading your airbox question, you don't) I wouldn't bother trying to swap over from injection to carburettor fuel system. You would be better off finding an old fashioned engine and trying to mount it in the car, but even then you will end up with loads of problems with the vehicle electronics.
My advice would be unless you have a Honda CBR 900, retract your bid as you will never get them to work on a 206.
A few details about your car might also help with normal advice, I can only work out that you have a petrol engine in your car after that I can't narrow it down to one of the 10 or so engine variations produced.
PostPosted: Thu Aug 02, 2012 5:38 am Up
i am pretty sure webber got a few conversion kit for the XU lump....
PostPosted: Thu Aug 02, 2012 8:45 am Up
Carbs on a 206 are a pointless idea, there's nothing wrong with the original injection system.
PostPosted: Thu Aug 02, 2012 8:46 am Up
Even the XU lumps run better on fuel injection Laughing
the.drewsta82
PostPosted: Thu Aug 02, 2012 10:52 am Up
206 gti both inlet and outlet coms done also remaped
sedrew
