Latest: cogeim7
Overall: 17185
Online Now [1157]:
Visitors: 1156
Today: 27930
Total: 147343797
Forums › The Car › 206 Problems › 206 gti 180 starting issue help please
bazzaboy1977
PostPosted: Wed Aug 08, 2012 4:51 am Up
Hi i have a 2005 206 gti 180 49k on the clock with starting issues when i start the car from cold or left for 12 hours it struggles to start first time when it does start its very lumpy and if you dap your foot on the accelerator it wants to cut out but when it's running it's a dream to drive i took it to the garage to have fault codes checked and there is none stored on removing the coil pack i did notice it has ngk spark plugs but not been able to remove them as only have a 21mm spark plug socket has any one else had the same problem? As I have been told its a coil pack on its way out
bmace
Big_Rich180
PostPosted: Wed Aug 08, 2012 5:03 am Up
Which thread do you want a reply to?
bazzaboy1977
PostPosted: Wed Aug 08, 2012 5:20 am Up
This 1 I done it on my Phone and it posted it 3 times
bmace
Lewis
PostPosted: Wed Aug 08, 2012 6:06 am Up
having the same problem as us by the sound of it. So any info would be much appreciate by all of us.
www.206info.co.uk/Foru...48421.html
Tivoli LX 1.1
Black GTI 180
White VXR Burg
NICKST
PostPosted: Wed Aug 08, 2012 11:21 am Up
Ngk plugs won't help the issue. Clean map sensors throttle body. And replace the crank sensor there not expansive just had a similar problem with a corsa I was doing some work on no fault codes stored but crank sensor was knackerd.
bazzaboy1977
PostPosted: Wed Aug 08, 2012 12:31 pm Up
What do they look like? Have just test fuel and the pressure is fine and just fitted bosh super 4S
bmace
Speeddemon180
PostPosted: Sat Aug 11, 2012 5:19 am Up
hey , my 180 is currently having issues , your and my problems are the alternator not working properly , mine starts but can't keep the volts up , battery light comes on followed by battery charge warning messsge on head-up display, my mechanic's told me not to drive my 180, in case i am miles from home with a dead battery....
A.chandler
DeadEyePaul
PostPosted: Sat Aug 11, 2012 5:48 am Up
What's the point of owning the car then? Should of got it fixed instead of telling you that
bazzaboy1977
PostPosted: Tue Aug 21, 2012 11:35 am Up
Hi I have done coil pack plugs still not starting well have now ordered a map sensor but have been told the problem might be down to the cambelt as it was changed over in January and if it was not tightened enough it might stretch and through the timing out
bmace
TheGTIlad
PostPosted: Thu Aug 23, 2012 3:30 pm Up
This may sound like a stupid thing, but i have once had a simalar problem myself with my 206 gti 138. Used to run the car, then come to it in the morning after running it at night, and it would struggle slightly to start. Checked everything ignition and sensor wise, no faults found. Same story with the diagbox software, no faults found. Turned out to be a small electrical drain on the battery. Never found the complete source of the electrical drain as I just put up with the struggling to start slightly.
bazzaboy1977
PostPosted: Mon Aug 27, 2012 12:57 pm Up
I have had the throttle position sensor reset and touch wood it has been ok
bmace
