Latest: jackrox1992
Overall: 17186
Online Now [821]:
Visitors: 821
Today: 67611
Total: 148232350
Forums › The Car › 206 Problems › re 206 temp gauge
re 206 temp gauge
wenmoll
PostPosted: Thu Aug 09, 2012 7:13 am Up
Hi just bought a 206 cc 1.6 petrol on a 52 plate it's got a funny temp gauge and reads quite high, if you start the car from cold first thing in the morning straight away the temp gauge starts at 70 and then goes up as it should whilst normal driving the trouble is because its starting quite high when it gets warm it looks like its overheating yet the fan is working as it should and its not pressurising i,ve changed the temp sender switch and still no difference heating is fine looks as if it the gauge but thought i,d ask before changing any suggestions gratefully recieved Cheers Dan
206 cc
PostPosted: Thu Aug 09, 2012 10:25 am Up
4 dial cluster with coolant temp gauge on right OR the 5 dial cluster with coolant temp gauge at bottom of rev counter & oil temp gauge on right?
wenmoll
PostPosted: Thu Aug 09, 2012 1:16 pm Up
hi the gauge is at the bottom of the rev counter cheers Dan
206 cc
PostPosted: Thu Aug 09, 2012 1:19 pm Up
Where is the gauge reading after a few miles / minutes of driving?
It should sit bang on 90 deg C for normal running temp once the engine is warmed up.
wenmoll
PostPosted: Thu Aug 09, 2012 1:34 pm Up
It runs about 100 degrees after a few mins of driving
206 cc
PostPosted: Thu Aug 09, 2012 1:37 pm Up
Is the thermostat opening at the correct temp to allow the coolant to circulate through the radiator?
Should open about 89 deg C.
