Posted: Tue Aug 14, 2012 12:14 pm |
I found this setting in my BSI using pp2000, basically its a speed warning system, if you go over a set speed limit it lets you know, i cant get it to work though! It come up on my MFD, but i cant set a speed limit. Does this need to be set in the BSI, or is it related to cruise control?
Posted: Tue Aug 14, 2012 2:37 pm |
| Steve206 wrote: |
| I found this setting in my BSI using pp2000, basically its a speed warning system, if you go over a set speed limit it lets you know, i cant get it to work though! It come up on my MFD, but i cant set a speed limit. Does this need to be set in the BSI, or is it related to cruise control? |
If that don't work you can use the other speed warming system that all cars have as standard-
the speedometer.
Posted: Tue Aug 14, 2012 3:30 pm |
| Steve206 wrote: |
The only thing that controls the speed of the car without driver input is the rev limiter.
Without cruise control you can't set a speed limit that the car can adhere to on a 206.
Saying that though, my VW has, as standard, a speed limiter/governor that isn't connected to the cruise control (accessed via the onboard computer) for winter driving etc. The 206 isn't that technical though lol
Posted: Tue Aug 14, 2012 3:42 pm |
You need the cruise control stalk fitted & also the cruise control working to use the overspeed warning on the 206.
Posted: Tue Aug 14, 2012 4:25 pm |
My Clio can either be switched to C/C or S/L, stupid 206's
| Renault Clio III RS - Race Car
Former Poverty 206 XS 1.6Turbo Owner  | |
Posted: Wed Aug 15, 2012 12:04 pm |
From what I know it is standard issue for all 206 sold in Saudi Arabia due to legislation there.
If they all have cruise-ctrl I don't know.
