Latest: tbafonso
Overall: 17130
Online Now [190]:
Visitors: 189
Today: 21855
Total: 103952213
Forums › The Car › 206 Talk › Coventry vs French built 206s?
Go to page Previous  1, 2
PostPosted: Thu Aug 16, 2012 2:50 am Up
mine was VF and it is make in coventry Laughing
PostPosted: Thu Aug 16, 2012 3:12 am Up
Mine is VF & was built ( badly ) at Ryton Laughing
PostPosted: Thu Aug 16, 2012 3:42 am Up
OK, cancel that then. Smile
For Europe is shows headquarters not actual place of manufacture.
Andrew
PostPosted: Fri Aug 17, 2012 8:58 am Up
I've just had a response from my local Peugeot, here is part of the email:
"I can confirm that your vehicle was built in Mulhouse France.This is determined by the last numbers in
the build code.It does vary on how the build number is displayed,but on the white label which is on the
door or door pillar the build code is displayed.The first 5 numbers relate to technical reference and the first
2 of the following number is where it was built.In the case of your vehicle 88 signifies Mulhouse."
My 206 thread
www.detailedbyandrew.com
PostPosted: Fri Aug 17, 2012 10:56 am Up
You pestered the dealer just for that???
PostPosted: Fri Aug 17, 2012 10:57 am Up
cool. never expect they will get back to you.
PostPosted: Fri Aug 17, 2012 11:20 am Up
They must have been having a quiet day.
PostPosted: Fri Aug 17, 2012 11:25 am Up
well they can't be that busy...
i remember last year i request a catalog from dealer and a few day later they phone in and ask me if i want to book in a test drive
PostPosted: Fri Aug 17, 2012 5:52 pm Up
Good info there.. Smile
Now ask him what the other places codes are.
Andrew
PostPosted: Fri Aug 17, 2012 6:27 pm Up
There is a guy who works there in service that has helped me out over the years, I asked him this in an email along with some other things. My local Peugeot are pretty good at helping me solve things via email I can't find the answer for on here - so it's not a case of pestering just for that, I pester about multiple things at once
My 206 thread
PostPosted: Fri Aug 17, 2012 7:17 pm Up
All other plant codes please.
Smile
Andrew
PostPosted: Sat Aug 18, 2012 4:53 am Up
I'll get on that for you
My 206 thread
Page 2 of 2
