Online Now [1121]:
Visitors: 1120
Today: 293144
Total: 149043252
Forums › The Car › 206 Problems › Water Pump // Noise from Engine
sjd92
PostPosted: Sun Aug 19, 2012 5:20 am Up
On previous MOTs my peugeot 206 1.1l had an advisory for noise from the engine.. and the garage told me its to do with the water pump... which may mean replacing the cam belt at the same time... which would be costly.. (at least at a garage)...
is it completely necessary to replace the cam belt with the water pump.. and is it possible / a hard job to do the pump by itself?
Bearing in mind my car's an 05 reg and only has 34,000 on the clock.
ukskater01
PostPosted: Sun Aug 19, 2012 5:27 am Up
The cambelt should be done every five years or 50,000 miles, yours is way over due and your lucky it hasn't snapped. Also the cambelt has to be removed to remove the pump, that's why most people do them both at the same time, where abouts are you in the uk?
PostPosted: Sun Aug 19, 2012 6:02 am Up
There is no logic for not fitting the cambelt, it has to come off anyway so for the price you may as well just fit another one on
Unless you know 100% it's been done within the last year, it should be done. + If yours has never been changed it NEEDS to be done now.
sjd92
PostPosted: Sun Aug 19, 2012 6:05 am Up
ontrue but its only done 34,000 miles.. and the cars only 7 years old...
Says your location is Sutton Surrey?.. not too far from there, down near Morden.
sjd92
broadblaster
PostPosted: Sun Aug 19, 2012 6:11 am Up
the milage don't really matter its the age of the belt it needs doing now mate !!!
on a back road playing
ukskater01
PostPosted: Sun Aug 19, 2012 6:16 am Up
I'm just round the corner from morden but moving in two weeks, ring around a few places or contact kris b. He done my axle replacement and was very good. He's about a 40 minute drive but I would highly recommend him.
His website: www.krisb.co.uk/category/pricing/
cartoonhead
PostPosted: Sun Aug 19, 2012 6:29 am Up
a garage suspect its the water pump , i'd have had the timing cover off just to make sure it is not the belt tensioner on its way out Wink
PostPosted: Sun Aug 19, 2012 6:30 am Up
Trust us, it needs doing it would crazy to strip it down and not fit a new belt when you are just going to have to pay another few hundred £££ to do it all over again later in the year hoping it doesn't snap.
Last time I checked they were less than £40
sjd92
PostPosted: Sun Aug 19, 2012 7:02 am Up
Ok then, I had a quote from my garage for the pump & belt and a few hours later around £400 (poss more or less it was only a guestimate) ... is this an average price in your view or more/less than would be expected for it?
sjd92
ukskater01
PostPosted: Sun Aug 19, 2012 7:06 am Up
Kris b should do it for around £200, depending on engine it might be a bit less!
sjd92
PostPosted: Sun Aug 19, 2012 7:14 am Up
Says £170 on the site.. ?
sjd92
cartoonhead
PostPosted: Sun Aug 19, 2012 7:22 am Up
brand new peugeot orig timing kit HERE ( £45.99 ) ,genuine water pump HERE ( £43.32 ) and at most 2-3 hours labour to fit and that's if they stop for dinner Wink
its allways cheaper to replace the pump and belt kit rather than the engine / head Wink
yours needs done sooner the better if you can hear it rattleing
ukskater01
PostPosted: Sun Aug 19, 2012 8:19 am Up
I just read your post again, I wasn't sure what engine you had Smile
sjd92
PostPosted: Sun Aug 19, 2012 9:27 am Up
yeah only a 1.1l ..
& am guna look into getting it done asap, thanks for all your help Smile
sjd92
sjd92
PostPosted: Sun Aug 26, 2012 6:19 am Up
Had the water pump done (& cam) although it had been replaced before.. (with a crappy part apparently) & that solved the noise ... Krisb did it for £170... cheers for the recommendation! ... I'd recommend him to anyone here too!
sjd92
