Posted: Tue Aug 21, 2012 2:54 pm |
Trade Rating: +16
hit a massive pot hole today just before going on to the slip road to the motorway now the steering wheel is vibrating at speed and also going side to side when braking, somtimes when going over speed bumps there is a little knocking from the front but not always
wisbones changed few weeks back along with track road ends (lemforder)
could the pot hole knocked my tracking off? could my wheels need re balancing after hitting it? or something else?
thanks
Posted: Tue Aug 21, 2012 2:55 pm |
dent alloy wheel
Posted: Tue Aug 21, 2012 3:11 pm |
Trade Rating: +16
thought the same cant see anything? i have another set so will see if it drives better with them
Posted: Tue Aug 21, 2012 3:13 pm |
Tracking is bound to be off, get it checked.
Posted: Tue Aug 21, 2012 3:16 pm |
Trade Rating: +16
will do, its free to get it checked at hi q, only charge if its off
f*****g potholes, been filled in before aswell thought it was sorted!!!
Posted: Tue Aug 21, 2012 3:36 pm |
anton1989 wrote: |
thought the same cant see anything? i have another set so will see if it drives better with them |
Just get the wheel that hit the pot hole on the wheel balancing machine, you will soon see if the rim is damaged when its spun up
Your getting the tracking checked so while your there get the wheel checked / balanced as well.
Posted: Tue Aug 21, 2012 3:38 pm |
Check the wheel balance, as well as obviously anything broken
| Team Impossible Possible
Posted: Tue Aug 21, 2012 4:17 pm |
Trade Rating: +16
The place I go to get my tracking done cant balance alloys with out a hole in the centre?
Will find somewhere though as it needs sorting asap
Posted: Tue Aug 21, 2012 5:30 pm |
Vortex wheels are a pain in the bum to get balanced as the tyre places cannot be arsed to change the setting on the machine(all tyre fitting places can do it) for love or money they fob you off!
There's a place in rugby that does mine if you like to know who. It's a place on albert st off railway terrace
Posted: Wed Aug 22, 2012 10:29 am |
anton1989 wrote: |
Sounds like a total p**s poor tyre fitting place then if there that tight they havent got the adaptor for balancing centreless wheels
Sounds like the sort of place to avoid to me
