Latest: ArtistKS
Overall: 17145
Online Now [93]:
Visitors: 91
Bots: 2
Today: 26412
Total: 116119566
Forums › The Car › 206 Problems › BSI unit
BSI unit
PugGti180
PostPosted: Wed Aug 22, 2012 10:40 am Up
BSI unit, is this why my rear auto wipe function and reverse lights no longer work?
2005 Peugeot 206 Gti 180, Silver, 38,000mls Wink
Rob2859
PostPosted: Wed Aug 22, 2012 10:45 am Up
Possibly but not likely. Could be the comms unit, maybe fuses? More information would be helpful.
PostPosted: Wed Aug 22, 2012 10:46 am Up
Probably the switch on the gearbox.
PostPosted: Wed Aug 22, 2012 10:47 am Up
What He Said
No reverse lights = no auto rear wiper.
If BSI cant see the switch input to turn the reverse lights on the auto rear wiper wont function Wink
Unplug the switch, short the 2 terminals together on the connector plug, turn the ignition ON & if the reverse lights now work buy a new switch.
PugGti180
PostPosted: Wed Aug 22, 2012 10:59 am Up
Its strange, there is power going to the lights but they won't illuminate. Tried bulbs, fuses, shorting it out etc but still no joy. Only stopped working after engine was swapped. Also new switch fitted too. Still no joy. Sad
PostPosted: Wed Aug 22, 2012 11:03 am Up
You have a high resistance wiring fault then & seeing as the engine has been swopped you need to check the wiring.
Until the reverse lights are fixed ( the BSI unit sees the reverse light switch ) the auto rear wiper isnt going to work.
PugGti180
PostPosted: Wed Aug 22, 2012 11:12 am Up
I see.:( I've traced the wiring all the way from the switch, in to the fuse box, out of the fuse box, along under the carpet in the car, all the way to the lights with no kinks or breaks or even bare wire?
PostPosted: Wed Aug 22, 2012 11:29 am Up
Its a HIGH RESISTANCE fault Wink
Dodgy / dirty connection or something not tightened up correct.
Shut the BSI unit down correctly & unplug it BEFORE you use a test meter on the wiring.
PugGti180
PostPosted: Wed Aug 22, 2012 11:32 am Up
Ok cheers. I'll see what happens. Smile
