Latest: Worthy967
Overall: 17143
Online Now [511]:
Visitors: 510
Today: 80645
Total: 114505861
Forums › The Car › 206 Problems › Rear Axel Bushes :/
Rear Axel Bushes :/
kenzie
PostPosted: Wed Aug 22, 2012 4:27 pm Up
i posted the other day were i thought the wheel bearing was casuing my wobble on the back and i have jacked it up at work to find out the bushed have worn on the n/s/r there is alot of side movement which is casuing the wobble
can you change the bushes on there own?
it must be eaiser and cheaper to do this than a new axel?
has anyone changed there bushes and did you use a guide?
would love any info to so i know what to do
Thanks Kenzie Very Happy
Red 206 GTi
Revenge is like a ghost. It takes over every man it touches. It's thirst cannot be quenched, until the last man standing has fallen. The world's men of action will look and wonder...how it came to this. You may be able to destroy me, but the beast will eventually come for you
PostPosted: Wed Aug 22, 2012 4:57 pm Up
do you mean those 4 rubber bush between the boot and the cross membrance on the axle?
kenzie
PostPosted: Wed Aug 22, 2012 5:00 pm Up
yes mate think so
Red 206 GTi
oh dear...
dealer got a special tools to pull the whole bush out.
without that you got to cut the bush into a few pieces and then chisel them out.
kenzie
PostPosted: Wed Aug 22, 2012 5:06 pm Up
oh damm :/ and you cant buy this tool?
Red 206 GTi
PostPosted: Wed Aug 22, 2012 5:31 pm Up
not i that i am aware of.
it is just a hydraulic puller + adaptor for the bush
you can certainly buy the puller, but not the adaptor.
kenzie
PostPosted: Wed Aug 22, 2012 5:37 pm Up
ok cheers matey
Red 206 GTi
usher
PostPosted: Thu Aug 23, 2012 4:04 am Up
pug told me its easy enough to pull them out with a bolt and socket make shift device
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Thu Aug 23, 2012 4:41 am Up
well, there is a diagram in the tech. manual.; i just can' get my head around that
Fifer
PostPosted: Thu Aug 23, 2012 5:10 am Up
Put a socket over one end that is bigger than the bush. Pass a bolt through from the otherside with a head or washer big enough to fit over the bush but not to have an overlap. Put a nut on the bolt sticking out of the socket. (The bolt thread will be where the ratchet would go). Tighten the nut. This will pull on the washer drawing the bush into the socket.
1.4hdi 02
usher
PostPosted: Thu Aug 23, 2012 11:57 am Up
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Thu Aug 23, 2012 12:23 pm Up
you done that before or that's an idea? i personally can't see how that would work.
DanT
PostPosted: Thu Aug 23, 2012 12:37 pm Up
Its quite a well known way of removing them/similar things, i've personally used the method lots of times (slightly different parts sometimes, but same principle) to remove bushes/bearings from motocross bikes, and trust me, they get seized in there!
PostPosted: Thu Aug 23, 2012 12:57 pm Up
i asked because i know that won't work or i done it wrong. there is no area for you to force to pull/ press out the bush with nuts, bolts and washer.
this is the guide from dealer:
www.peugeot206cc.co.uk...dj03a3.htm
Tools 5 is the key.
this is the guide i am following:
www.205gtidrivers.com/...eamrefurb2
DanT
PostPosted: Thu Aug 23, 2012 1:22 pm Up
Yeah thats fair enough, i'm just saying i've removed many things that way when i didnt have the correct puller to hand.
I've also removed them using similar methods the guide on the second link you showed. (Seems to be a good DIY way looking at these specific bushes)
I've also set fire to the ones on saxos/106's and then removed the metal outer once the rubber has all burnt away. Sounds a bit pikey but it works!
Edit: Just seen the burning option on link #2
