Latest: ArtistKS
Overall: 17145
Online Now [321]:
Visitors: 320
Today: 39345
Total: 116132488
Forums › The Car › 206 Problems › Help with Oil change on a 1.6 (TU5JP4)??
206Xt
PostPosted: Thu Aug 23, 2012 6:23 pm Up
Hi guys,
I'm struggling a little with changing the oil on my Pug... I can't find where the drain plug is located!
I've seen lots of pics of other engines and none seem similar to mine... I only see a plug that seems to go out with an allen key (on the back left side of the oil pan - as seen from the front), but it has no head like to use a 21mm socket (as I've seen in this forum most of the other models have).
Can anyone help? Pics are very much appreciated.
Regards!!
Are we talking or are we racing...?
PostPosted: Thu Aug 23, 2012 8:48 pm Up
You need to use the correct tool, not all oil drain bungs are hex headed Wink
PostPosted: Fri Aug 24, 2012 2:45 am Up
Would this engine have the square hole in the sump plug? The bodgers would use a 3/8 ratchet to get it out but you should really get the proper 8mm tool.
Ape
PostPosted: Fri Aug 24, 2012 3:20 am Up
Aye, a drain plug set doesn't cost much and is better than bodging.
PostPosted: Fri Aug 24, 2012 11:26 am Up
My TU3 lump needs the square key to remove the sump bung, the correct tool is cheap.
PostPosted: Fri Aug 24, 2012 11:40 am Up
would be easier to drill the sump and then plug the hole back with a wine cork after the oil change
PostPosted: Fri Aug 24, 2012 11:47 am Up
Be easier to just swop the standard bung for the quick drain type, saves on drilling & no more tools needed to drain the oil Wink
PostPosted: Fri Aug 24, 2012 11:59 am Up
i always though those thing would seized when ever you want to do the oil change Laughing
206Xt
PostPosted: Sat Aug 25, 2012 4:16 pm Up
Yeah, it's exactly like that one. Thank you for your answers, I'll try to find the correct tool...
