Latest: S2cgm
Overall: 17178
Online Now [80]:
Visitors: 80
Today: 22925
Total: 137554173
Forums › The Car › 206 Problems › MOT Advisory [7.1.2], Should I act?
very_452001
PostPosted: Thu Aug 23, 2012 3:47 pm Up
Hi,
I got a mot advisory # [7.1.2] stating that the front exhaust has a minor leak of exhaust gases? Will this effect mpg figures?
If i ignore this advisory will that minor problem turn to major problem in the future?
What does a typical garage do to fix this advisory?
Thanks,
very_452001
PostPosted: Thu Aug 23, 2012 3:49 pm Up
it will
it will
depends on where is the leak; if it leak through joint normally they just paste it and re-tighten. if there is a crack they might weld it back or replace.
PostPosted: Thu Aug 23, 2012 3:57 pm Up
I got an advisory for this, it ended up being a small hole where the O2 sensor boss is welded to the pipe. Some exhaust paste sorted it until I can afford a new cat.
very_452001
PostPosted: Thu Aug 23, 2012 4:57 pm Up
Seabook wrote:
it will
it will
its at the front
very_452001
marc206
treat the car to a new system Wink
very_452001
PostPosted: Thu Aug 23, 2012 5:05 pm Up
yeah if i had the new money lol
very_452001
very_452001
PostPosted: Thu Aug 23, 2012 5:35 pm Up
Seabook wrote:
it will
it will
can you give me a guide price on how much a typical garage should charge for the job you mentioned so i know which quotes are genuine. thanks,
very_452001
dan.brown.120393
PostPosted: Thu Aug 23, 2012 5:55 pm Up
Slightly off topic but I think if a exhaust is leaking it should be a fail no matter how small. However if it is just a leaking joint, clagg it with exhaust paste, VOSA dont mind that
Dan Brown
PostPosted: Fri Aug 24, 2012 6:13 am Up
very_452001 wrote:
Seabook wrote:
it will
it will
its at the front
new gasket
very_452001
PostPosted: Fri Aug 24, 2012 9:36 am Up
Seabook wrote:
very_452001 wrote:
Seabook wrote:
it will
it will
its at the front
new gasket
how much does a typical garage charge for this so I avoid to get stung by a greedy mechanic?
Is this gasket a seal type gasket that stops the leaks?
very_452001
PostPosted: Fri Aug 24, 2012 10:52 am Up
Without knowing exactly where the leak is, it's impossible for anyone to say how much it will cost
very_452001 wrote:
its at the front
Doesn't really narrow it down. Is it a join? is it a hole? is it on the manifold or the front pipe? is the catalyst on the front pipe or the centre pipe?
The best way to find it is with your hands. When the engine is cold (to avoid burning yourself accidentally) Start the engine and get a mate to hold a folded cloth over the tail pipe to seal it. Lie underneath the front of the car, should be enough room to get your head under too if it hasn't been lowered and look for the leak. You may see a visible mark, usually soot around a leak, or you may need to place your hand near the pipe and feel for air hitting your hand.
Once you have located the leak then it will be easier to advise on the best course of action to fix it.
If needs be and you're not entirely sure how to describe where the leak is, mark the hole with white chalk or paint, take a picture and post it on here for advice.
very_452001
PostPosted: Tue Aug 28, 2012 2:07 pm Up
Update:
I been to national tyres and autocare to sort this problem out and they saying they cant do it because they need the exhaust fitting kit for the 206 which they dont have.
They advise me to go to kwik fit as they might have the kit.
Its leaking at the joint.
Isnt the catalyst location same for all 206 cars?
very_452001
Ash
PostPosted: Tue Aug 28, 2012 2:09 pm Up
Don't go Kwik Fit if you care for your car.
gazza82
PostPosted: Tue Aug 28, 2012 2:27 pm Up
Go to an independent exhaust fitter ...
The front exhaust clamp is cheap and simple to fit (if you can reach) ... I got one from a local motor factors for about £2. Some have one bolt and others two ...
Coolspot
PostPosted: Tue Aug 28, 2012 3:22 pm Up
Get the garage to show you where the lea is as quite a lot of people trust garages too easily leading to being over charged.
but as said above as it is a join it just a simple enough job to have done or a load of paste Smile
206 3dr 1.4 GLX modified slightly, Lowered 35mm on full Gmax kit, 17" AEZ xylo alloys 205/45/17, 3.5" Savage back box,
