Latest: lio94
Overall: 17181
Online Now [268]:
Visitors: 267
Today: 30811
Total: 141785387
Forums › The Car › 206 Problems › 206 wants sleep ?
206 wants sleep ?
SteveTDCi
PostPosted: Fri Aug 31, 2012 1:06 pm Up
Our little 206 1.48v (1999) has just started to play up, the wife complained about it on the way home so i've just run around the block in it and it decided to give me the run around.
The only symptoms I have are .... it doesn't want to rev, it didn't sound like it was a missfire but it kind of gave the feeling of trying to accelerate against a missfire, it just would not rev. I dropped the clutch in stamped on the accelerator and it picked up and revved freely. It drove normal for 2 minutes and then cut out. It started perfectly and then drove fine. It feels like your driving against the brakes
I've had a quick look under the bonnet and nothing appears to be loose or undone the only thing that felt hot was the radiator and top hose, i'm not sure if it was hotter than normal as i don't go around feeling the hoses all that often. The car has had the hg done and the oil is clean and it has no water or mayo.
The only thing i have noticed is just lately on very light throttle you can feather it and it feels almost like a switch, but other than that nothing. It still returns 40mpg no matter what and there are no lights on the dash.
Any pointers would be great, if not Vera goes on ebay Smile
206 1.4 LX ... its called Vera and is built for abuse, but needs a few things, including hoovering out
anton1989
PostPosted: Fri Aug 31, 2012 1:38 pm Up
Trade Rating: +16
coilpack maybe?
SteveTDCi
PostPosted: Fri Aug 31, 2012 2:05 pm Up
That was my initial thought, it's on it's original one the only doubt was that it's never misfired or anything and it's just suddenly going.
shell-vt
PostPosted: Fri Aug 31, 2012 2:15 pm Up
Trade Rating: +46
i kinda have the same problem but its a air intake leak
york 16,3
SteveTDCi
PostPosted: Fri Aug 31, 2012 2:28 pm Up
Interesting, have you traced the leak ? I can pull all the intake off tomorrow and check.
PostPosted: Fri Aug 31, 2012 2:55 pm Up
No coil pack on a hdi! Sounds like a turbo or intake problem.
anton1989
PostPosted: Fri Aug 31, 2012 3:01 pm Up
Trade Rating: +16
FAIL
Laughing
SteveTDCi
Mines petrol Wink
Matt
PostPosted: Sat Sep 01, 2012 4:56 am Up
Trade Rating: +32
Could be loads of things. It's similar to a problem I'm having.
Service
MAF/MAP sensor
Coil pack
Spark plugs
Throttle sensor
Air in the system
Gearbox earth
These are a few things I've tried/checked/cleaned so far. I've not replaced anything as yet but obv makes sense to start with the cheapest bits first ie plugs.
SteveTDCi
PostPosted: Sat Sep 01, 2012 5:21 am Up
It's had plugs, air filter fuel filter in the last 5k. I've been out and cleaned the throttle body and idle speed control valve. It hasn't played up on the test run so hopefully the dirt I've cleaned off was the problem. Just thinking about it, it felt like it was being starved of fuel. Anyway I'll see what happens. I know it's old but if it starts giving me trouble then it will be up forsale very soon
Matt
PostPosted: Sat Sep 01, 2012 6:09 pm Up
Trade Rating: +32
Cleaning the MAF, checking the Gearbox earth & and checking for air in the system are all free to do, so id try those next.
138Andy
PostPosted: Sat Sep 01, 2012 6:29 pm Up
if vera goes on ebay let me know Wink
PostPosted: Sun Sep 02, 2012 5:00 am Up
anton1989 wrote:
FAIL
Laughing
LOL, no idea why i thought that!
Coolspot
PostPosted: Sun Sep 02, 2012 8:53 am Up
I would say map sensor as this has happened to or picasso and i swapped the map sensor to the 206 and it showed the same problem as the sensor is the same problem. £15 ebay
206 3dr 1.4 GLX modified slightly, Lowered 35mm on full Gmax kit, 17" AEZ xylo alloys 205/45/17, 3.5" Savage back box,
SteveTDCi
PostPosted: Sun Sep 02, 2012 9:57 am Up
Ok after cleaning the ISCV again, i think i've ruled it out, if you hold the revs at 2k it drops by 50rpm every few seconds then rise's, so i guessing there is a possibility that its the coilpack on the way out. It seems fine elsewhere and it only has a kitten when pulling away at low speed under load and not accelerating hard. I think i'll just pick one up from eurocar parts, they are only £42 at the minute which is cheaper than paying an hours labour. If that doesn't fix it i'll put the coilpack on here Smile It still might end up on ebay though. I've had it too long (7 months)
