Latest: Beduff1977
Overall: 17134
Online Now [637]:
Visitors: 636
Today: 67970
Total: 108404334
Forums › The Car › 206 Talk › BE4/5 Gearbox oil sourcing troubles
Go to page Previous  1, 2
SinfulDesignCom
PostPosted: Sat Sep 01, 2012 1:27 pm Up
Manufacturers only came out with the higher viscosity to give gearboxes a longer oil change period - providing you change the oil frequently you can throw 10/40 in and you will have far better performance Smile
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
gazza82
PostPosted: Sun Sep 02, 2012 8:14 am Up
I do hope that you were joking!!
10W40 isn't going to take the pressures that you get in between the gears ... 10W40 is engine oil and isn't designed for gearboxes ...
SinfulDesignCom
PostPosted: Sun Sep 02, 2012 9:11 am Up
You never raced an 'A' series??? Smile
PostPosted: Sun Sep 02, 2012 9:17 pm Up
Different formulation altogether and no sulphur in engine oil.
I know people have done it but anything other than BV 75W80 is a giant cockup in my experience let-alone engine oil in there..
gazza82
PostPosted: Mon Sep 03, 2012 9:59 am Up
As in Mini engine?
My first car had 948cc's and used 20W50 mineral oil .. also had RWD!
... but I'd still not stick that in a gearbox or diff!
PostPosted: Mon Sep 03, 2012 11:02 am Up
There are plenty of cars still on the road where the manufacturer states that engine oil of 10w 30 or 10w 40 is what should be used in the gearbox.
Most cars use gearbox oil BUT some need engine oil as putting gearbox oil in actually ruins the gearbox.
You should always refer to the manufacturers recommended oil specification for the car in question, they designed & built it so they know what lubricant to stick in it.
PostPosted: Mon Sep 03, 2012 11:17 am Up
loads of engine oil oil got MoS2 nowadays
PostPosted: Mon Sep 03, 2012 2:24 pm Up
That's molybdenum dioxide, I thought gear oil had straight sulphur in it. Smile
PostPosted: Mon Sep 03, 2012 3:38 pm Up
that's molybdenum disulphide
PostPosted: Mon Sep 03, 2012 3:53 pm Up
That's the one. Is that used in gear oil?
I thought it was actual form of sulphur used which gives it the characteristic smell.
PostPosted: Mon Sep 03, 2012 3:55 pm Up
I thought it was another form of sulphur used which gives it the characteristic smell.
yes, so as in some of the engine oil and CV joint grease
commerical grade molybdenum disulphide always contaminate with elemental sulfur.
PostPosted: Mon Sep 03, 2012 4:29 pm Up
So, can you make lysergic acid diethylamide if I send you all the stuff?
SinfulDesignCom
PostPosted: Mon Sep 03, 2012 5:11 pm Up
Jesus - what have I done!! I only said you could use the damn stuff. Being of lower viscosity, forgetting the chemistry lesson, it will offer better performance given it will allow for free movement - imagine walking through water and then through treacle...
Maybe an issue used long term on newer boxes - but to iterate a point, look at early Saabs, Honda, Peugeots, Mini... many more - all use engine oil in the gearbox. They were fine. But adding an extra 2-3 litres of oil to each lubrication service soon became expensive. Hence a fluid which only required a change every 40-50k.
That was my point - nothing more. I will let you know how my gearbox is after a few sessions at Brands Smile
PostPosted: Mon Sep 03, 2012 5:35 pm Up
Laughing
i always though that is the only reason why people staying late night and holidays in the lab.
Page 2 of 2
