Latest: jackrox1992
Overall: 17186
Online Now [871]:
Visitors: 870
Today: 141990
Total: 148668257
Forums › The Car › 206 Problems › Non Start/Cutting out once bump started on a GTi
Still_Rolling
PostPosted: Fri Sep 07, 2012 1:25 pm Up
Hopefully someones got an idea whats up with my car, or can give me some pointers
206 GTi 140, on a Y reg.
Tried to start my little bad boy last night, turned the key, all I got was a clicking noise, sounded like the solenoid but no turnover.
Bump started it down the road, it fired up, then cut out. Tried turning it over again, and nothing.
Bump started it again, again it fired up, then cut out straight away again.
Borrowed jump leads from a neighbour, hooked it up to my brothers car, again all I could hear was clicking from the solenoid. I thought it could be starter motor or battery related, but then it wouldn't have cut out once it was running would it?
Anyone got any ideas what it could be, i.e crankshaft or camshaft sensor, MAP sensor, common bad earth etc? Really need to be back on the road by Monday night because it's my boy's first day at school on Tuesday.
Always Rolling...
PostPosted: Fri Sep 07, 2012 1:43 pm Up
Sounds like a bad earth
PostPosted: Fri Sep 07, 2012 2:30 pm Up
Connect the battery -ve direct to the body then try to start it. or connect engine directly to body.
Still_Rolling
PostPosted: Fri Sep 07, 2012 3:17 pm Up
Cool, I'll give it a try in the morning. Thought it might be something like that but I wouldn't know where to start. If connecting the negative to the body fixes it, what's the next step? How do I find the bad earth?
Always Rolling...
Still_Rolling
PostPosted: Sat Sep 08, 2012 8:47 am Up
I've tried the earth, hooked up the -be to 2 different places on the body an to the gearbox, nothing at all. Could it be immobiliser related?
Always Rolling...
Still_Rolling
PostPosted: Sun Sep 09, 2012 7:34 am Up
Can anyone help me out here? I've been out to the car today, the batteries completely flat. I've tried jump starting it off my brothers a3 tdi, but the same things happened. Could a faulty battery stop it being being jump started off of another car? Or could there be a big electrical problem causing a short circuit so there's just no current gettin to the starter?
Always Rolling...
Ali_H
PostPosted: Sun Sep 09, 2012 6:50 pm Up
Jump starting a 206 isn't a great idea anyway, you run the risk of buggering the ECU. Try taking the battery off another car and starting it.
kurtis wrote:
Still_Rolling
PostPosted: Tue Sep 11, 2012 7:02 am Up
Twas' the window switch stuck which drained and murdered the battery. New battery fixed it, boom!
Always Rolling...
PostPosted: Tue Sep 11, 2012 12:37 pm Up
Once the battery is flat it needs charging, just driving it won't charge it properly. So a jump start will just get you going...
