Latest: cogeim7
Overall: 17185
Online Now [843]:
Visitors: 843
Today: 135662
Total: 147431238
Forums › The Car › 206 Problems › Moretes lights
Moretes lights
lee-b
PostPosted: Sat Sep 08, 2012 12:22 pm Up
right iknow this has been covered many times but i just cant seem to figure out what is wrong when wiring up my lights i can only get my side lights & my full beams to work but not my dipped. i have pictures of the wiring.
thanks.
138Andy
PostPosted: Sat Sep 08, 2012 12:32 pm Up
wouldn't know until you put them in your car because cant see what your doing wrong :/
lee-b
PostPosted: Sat Sep 08, 2012 1:09 pm Up
good shout haha wiil do it tomroorw now
iainlovatt
PostPosted: Sat Sep 08, 2012 2:27 pm Up
explain to me your wires! Smile
morettes are simple to wire in
the passenger requires a power and earth and the drivers one requires just an earth!
Simples!!
(My Garage)
iainlovatt
PostPosted: Sat Sep 08, 2012 3:07 pm Up
Right
Pic one, see the yellow cable doing nothing, add some wire to it and earth it
Pic 2 see the yellow cable doing nothing add some cable to it and earth it, also see the cable with a ring on it give it some power! Smile
Thats why they didnt work! because you only wired in the ones stated!
(My Garage)
lee-b
PostPosted: Sat Sep 08, 2012 5:50 pm Up
i just plugged in all the connectors into where i unplugged my old ones from also the cable with the ring on it i though that was meant to be earthed. first time changing lights and new to all this so thanks for help Smile
iainlovatt
PostPosted: Sun Sep 09, 2012 4:23 am Up
ok keep me informed! C Smile
(My Garage)
lee-b
PostPosted: Mon Sep 10, 2012 3:03 am Up
ok so never managed to get them done beacuse i was called into work untill about 6ish then it started raining ahhh. ohwell there is always tonight.
mehoolkmusic
PostPosted: Mon Sep 10, 2012 3:10 am Up
I drove with mine at night with Osram cool blue intense, was not that great thought.. Stuck the crystals back on :), H.I.D Kit on the morette dipped beams are far better IMO
Left French. Drive a Astra coupé 2004
www.soundcloud.com/mehoolkmusic
kurosagi01
PostPosted: Mon Sep 10, 2012 4:01 am Up
Have you checked if your fuses hasn't blown? I had that problem with my angels i couldn't get the dipped beam to work from the main connector,but after checking the fuses couple months later on i realised i've blown the fuse of my dipped beam so i replaced it and got it to work.
Check your fuse box in the engine bay compartment and look for the dipped beam fuse which should state in your drivers manual,or there is a picture somewhere on 206info can't remember which thread though.
iainlovatt
PostPosted: Mon Sep 10, 2012 4:03 am Up
It didnt work because he forgot to connect all the wires up Smile
(My Garage)
lee-b
PostPosted: Tue Sep 11, 2012 1:28 pm Up
so after yesterday wasted cuz was p**sing of rain but was bright and sunny today and finally managed to get them on and working. thanks for the help guys Smile Very Happy
iainlovatt
PostPosted: Tue Sep 11, 2012 2:47 pm Up
No problem! Smile
(My Garage)
mehoolkmusic
PostPosted: Tue Sep 11, 2012 3:58 pm Up
My turn next! Very Happy
DeadEyePaul
PostPosted: Tue Sep 11, 2012 4:04 pm Up
Love it! You struggled but the end result was worth it
