![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Problems › 206 lx 1.1 litre, engine management light etc... HELP?!! |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Mon Sep 10, 2012 7:44 am |
deskchair5, it starts straight away, it gets to around 90 on the temperture gage then thats when the light comes on and it cuts out, and loose power, but restarts straight after, and iainlovatt where abouts are you from so i could pick them up?
| | ![](images/spacer.gif) |
Posted: Mon Sep 10, 2012 7:49 am |
iainlovatt wrote: |
if its not coming up with faults then its intermittent, my best guess is a coil pack, i had the same issue with my 1.1, so i bought a new coil pack but never fitted it as i just decided to hit the coil pack with a spanner and it seem to fix it, ![Smile Smile](images/smiles/icon_smile.gif)
even trying coilpack earth mod would be good idea.
Posted: Mon Sep 10, 2012 9:50 am |
I had a similar issue on my TU3JP lump. It would run fine, cut out slowing down on the approach to a junction, all the usual lights on the dash would come on as expected with a stalled engine. Turn the key and car would restart and be fine. Ended up being the battery on the way out.
Check it with a multimeter. If it's healthy it should read about 12.6v at rest and about 14v when the engine is running. Mine was reading <12v at rest so put a new battery on and not had a problem since.
Posted: Tue Sep 11, 2012 4:53 am |
ill keep that idea on my mind, could be any kind of things, just want to get it fixed asap because i cant drive it yet ![Sad Sad](images/smiles/icon_sad.gif)
| ![](themes/base/images/forums/otr.gif) |
