Online Now [447]:
Visitors: 446
Today: 24434
Total: 142292944
Forums › The Car › 206 Problems › Oil in the Water Tank
DangGina
PostPosted: Mon Sep 17, 2012 8:31 am Up
hello all...wondering if you can help!!!
Have had the starter motor replaced last weekend in my 52 reg SW and the mech noticed oil in my water tank. he drained it (didnt have time to fully flush out however) and said see what its like today. low and behold its back in there today.
no other HG symptoms, car runs fine, no overheating, and i cant see any coolant in the oil?
could this be something else before i shell out for a new hg, but if i did what could i expect to pay for this?
Abzynthe
PostPosted: Mon Sep 17, 2012 8:35 am Up
East Area Rep - Abzynthe
I would probably get it flushed and then see if it comes back. What you saw today could be what had stuck to the pipes when the system was drained.
DangGina
PostPosted: Mon Sep 17, 2012 8:38 am Up
can i get that done as part of a full service, needs mot doing mid next month so might as well. debating on waiting that long tho!
Abzynthe
PostPosted: Mon Sep 17, 2012 8:42 am Up
im not sure if they would charge extra for it, but they would be able to do it at the same time as a service. I had a leak on my radiator so I got the whole lot done at once. Full service, cam belt, coolant flush ect.
DangGina
PostPosted: Mon Sep 17, 2012 9:03 am Up
hmmm. ok thank you!
I am wondering if its not the HG, I only had it 8 months and wondering if it was done preivously..no service records.
i have had hg go and driven for miles after (one did another 10k) so assume that as there is no other symptoms its ok to continue driving for a nother week or so. only do 20 miles a day.#
PostPosted: Mon Sep 17, 2012 12:18 pm Up
of cause they can do it for you, in the exchange of your money.
PostPosted: Mon Sep 17, 2012 3:39 pm Up
Its probably the headgasket, or something along that lines allowing the main oil gallery to mix with the water
I dont suppose it has a heat exchanger yours? (i think they were only really seen on 406's, but who knows)
Rob2859
PostPosted: Mon Sep 17, 2012 8:27 pm Up
Probably looking that way. Get a pressure test done its a stand and wait job. It will tell you straight away.
