Online Now [176]:
Visitors: 175
Today: 3137
Total: 142271662
Forums › The Car › 206 Problems › horrible wheel noise?!!!!!!
Baxter4130
PostPosted: Tue Sep 18, 2012 2:05 pm Up
this has started to happen since lastnight. its annoying the life out of me!!
tried to make a small of clip of it, you can hear it...like a tinny sound.
s270.photobucket.com/a...noise2.mp4
s270.photobucket.com/a...noise1.mp4
booorrrrrrrpppp tshhhhhhhhhh!! Smile
richpowell91
PostPosted: Tue Sep 18, 2012 2:11 pm Up
Hard to tell from the video but first thing i would do is, jack the car up take the wheels off and check the brake pads to make sure there not low, also check for stones etc that could be trapped. Could also be the disc protector/backing plate, so check thats not catching the disc as you spin it round.
If none of the above check for play in the wheel as it could be the wheel bearing on its way out.
Baxter4130
PostPosted: Wed Sep 19, 2012 2:08 pm Up
that thing turned out to be what looks like a metal ring that was sitting behind the wheel bearing, it was cracked in half :/ the ring fell out, noise is all gone
