Online Now [145]:
Visitors: 144
Today: 69240
Total: 143195698
Forums › The Car › 206 Problems › Another problem :/
Another problem :/
dan_manu
PostPosted: Wed Sep 19, 2012 5:18 pm Up
right, so today i decided to fit the carbon fibre dipped console that i brought from anthony, i took off the old centre console using a flat screw driver to just pop the top of the console off and then carefully pulled the bottom of the console off. After swapping the hazard button around and fans around i put the new centre console on which by the way looks great by the way :D. i put my headunit back on and noticed that the screen at the top of my console isn't working now and every time i do someone that involves electric e.g. flash my high beams/ turn lights on my sub in the back like pops :/ im going to have a proper look at it tommorow but im rubbish at electrics, does anyone have any advice or idea's that i could try? it would be very much appreciated as i really dont have the money to give to a mechanic
Thanks Danny
ARRAN
PostPosted: Wed Sep 19, 2012 5:32 pm Up
Loose connection on RCAs hedunit end, take the stereo out, squeeze the RCAs so they fit a bit tighter.
See my project here.
dan_manu
PostPosted: Wed Sep 19, 2012 5:40 pm Up
ok mate il try that tomorow in the daylight, i realy hope it works :/ the amount of problems im getting from my 206 haha, would that cause the sub to 'boom' after i turn my lights on etc ?
ARRAN
PostPosted: Thu Sep 20, 2012 3:49 am Up
Yep, because it has a loose connection one of the RCA's causing interferance. I'm almost certain this will solve your problem, I had this problem for months in my 106, finally decided to play around with the headunit and the RCA's, and problem solved! Hope it works for ya.
dan_manu
PostPosted: Thu Sep 20, 2012 3:00 pm Up
would you have any ideas about fixing the centre console display at the top because thats not working now ?
Thanks Danny
