Online Now [235]:
Visitors: 234
Today: 16176
Total: 142638013
Forums › The Car › 206 Problems › speedo not illuminated
spiritse
PostPosted: Thu Sep 20, 2012 1:24 pm Up
Hi,
I have a 206 2.0 HDI, 2001 plate.
The speedo has stopped working and also the time clock, preplex system.
Is there a fuse for these or a way to test the circuit board the bulb seems seems fine swapped from another warning light to test. also are they on a joint circuit?
Regards
Jason
206 2.0HDI 2001
madigg
PostPosted: Thu Sep 20, 2012 5:19 pm Up
I blew a few LED's while changing my stereo system - result was no illumination on the speedo, tachometer or clock. I also blew one of my sidelights. I checked the fuses, one or two had gone (sorry I can't be more specific, I don't remember which ones precisely but they were within the top two rows in the fusebox on the drivers side). Thing is, I replaced the clock LED and it works perfectly. I replaced the illumination LED's and they are still not illuminating for some reason. I'm stuck as I know the LED's work (I've tested them with 12v) and I know my fuses are all good.
djdan0123
PostPosted: Thu Sep 20, 2012 5:28 pm Up
On the back of the fuse no cover should be a chart saying why fuse is what check the fuses
Build your own dreams, or someone will hire you to build theirs.
Life's a gamble, Take your chances.
stoisha
PostPosted: Tue Oct 02, 2012 6:23 pm Up
lol i just smacked the top of my speedo gauge Smile it was annoying me then it workedd
