Latest: tbafonso
Overall: 17130
Online Now [281]:
Visitors: 280
Today: 7433
Total: 102933057
Forums › The Car › 206 Problems › powersteering fluid
powersteering fluid
Go to page Previous  1, 2
PostPosted: Thu Sep 27, 2012 2:05 pm Up
macca1411 wrote:
According to Haynes the capacity for power steering fluid is 1 litre approx.
Works out about £20 per litre from dealer for the Total brand. Esso is cheaper by about £5, they also list the same stuff for auto box top up.
you sure?
i just check the technical guide it said:
RECOMMENDATIONS POWER STEERING FLUID (SERVICE)
The hydraulic fluid DEXRON 2 can be used for the following vehicles (Temperate climates) :
106 - 206 - 306
406 - 607 - 806
PARTNER - EXPERT - BOXER
NOTE : for versions for very cold climates: the hydraulic fluid TOTAL FLUIDE LDS H50126 or the hydraulic fluid PENTOSIN CHF11S must be used .
and dexron 2 oil is dirt cheap Confused
PostPosted: Thu Sep 27, 2012 2:06 pm Up
We just use motoquip s**t at the dealers now Laughing
About £14 i think?
PostPosted: Thu Sep 27, 2012 2:41 pm Up
Seabook wrote:
cool.
do i need any special tools to remove the pipe?
i presume i have to turn the steering wheel when engine is running? wheels on the ground or not?
Engine off, wheels on the ground 10 times lock-to-lock then engine on 10 more times lock-to-lock.
From PSA:
(H) : Maximum level (Hot) .
(C) : Maximum level (Cold) .
IMPERATIVE : use new fluid when filling and topping up the system .
Fill the power steering reservoir 10 to mm above the maximum mark (A) .
With the engine stopped, Turn the steering slowly from lock to lock in each direction : Approximately 10 times .
Again fill the reservoir up to the maximum level (A) .
4 - BLEEDING
Run the engine at idle for 2 to 3 minutes without moving the steering wheel .
Keep the fluid level topped up .
Bleed the circuit by turning the steering several times in each direction .
(A)Maximum level .
The level must be set with the engine stopped and the wheels straight ahead
PostPosted: Thu Sep 27, 2012 2:43 pm Up
V9977 wrote:
Seabook wrote:
cool.
From PSA:
4 - BLEEDING
(A)Maximum level .
thanks
actually i have just check that one out Laughing
PostPosted: Thu Sep 27, 2012 2:44 pm Up
Ah, but I wrote it all from memory.
Page 2 of 2
