Posted: Wed Sep 26, 2012 5:12 pm |
Hi shellysexbomb,
I've had the same problem but fixed it today, it was the input pipe to the filter.
The air box had been rubbing and chaffing it over 75000 miles, it created an absolutely minute hole.
I replaced the pipe and rerouted it, problem solved.
Posted: Thu Sep 27, 2012 4:18 am |
| 02exe wrote: |
Common problem, 207 1.4 HDI suffers from this as well
Posted: Thu Sep 27, 2012 9:46 am |
mines getting worn there too, though pug quoted me over £100 for the replacement pipes....i know it'll need doing soon...curse Peugeot's rubbish design....
Posted: Thu Sep 27, 2012 1:29 pm |
| southwestchap wrote: |
| mines getting worn there too, though pug quoted me over £100 for the replacement pipes....i know it'll need doing soon...curse Peugeot's rubbish design.... |
£100??????????????? What a rip off.
It cost me £1 for some clear braided PVC tube and about 30mins to do.
Now I've done it once I could fix the next one in 10mins, I also re-route the pipe to prevent it happening again.
Posted: Thu Sep 27, 2012 2:57 pm |
Oooohhh O2exe are you perchance anywhere near the wakefield/west yorkshire area? ;o)
Posted: Thu Sep 27, 2012 5:46 pm |
| shellysexbomb wrote: |
| Oooohhh O2exe are you perchance anywhere near the wakefield/west yorkshire area? ;o) |
Sadly not I'm afraid, I'm in sunny Suffolk.
Would a picture be any use to you?
All you need to do the job is a sharp knife and 1/2 meter of 8mm Braided tube.
Posted: Sat Sep 29, 2012 2:41 am |
Oooh, a picture would be very useful I am more than happy to have a go myself before throwing anymore money away :o)) Thanks o2exe :oD
Posted: Sat Sep 29, 2012 7:33 am |
I'll get one today and post it up then.
I have noticed the even the most minuscule amount of air will cause an engine shut down or failure to start.
When corrected it really is a pleasure to drive with confidence and a bit of welly now and again.
