Online Now [108]:
Visitors: 107
Today: 24953
Total: 138760246
Forums › The Car › 206 Problems › Rear LED brake light problem!!!
tjchimp
PostPosted: Sun Sep 23, 2012 2:05 pm Up
just having a slight issue with some led rear lights. when you turn the lights on everything is fine. when you brake the right and 3rd brake light come on fine. but the left light just dims. wondering if anyone had had the same problem and what the solution was.
stoisha
PostPosted: Tue Oct 02, 2012 6:21 pm Up
it might be the connections under the dash at the passengers side just mess about with them till they come on i had the same problem and i got it fixed by doing that lol hope i helped a little bit
andyleep
PostPosted: Wed Oct 03, 2012 10:36 am Up
I would try a new bulb first of all
tjchimp
PostPosted: Mon Oct 08, 2012 11:56 am Up
ill have a play with the switch under the dash and i would try a new bulb if they were bulbs.
If it ain't broke, don't fix it... If it is broke, hit with a hammer until it works again. Or just buy a new one.
