Online Now [286]:
Visitors: 285
Today: 85629
Total: 142797885
Forums › The Car › 206 Problems › MFD Fault
MFD Fault
dazw30
PostPosted: Sat Oct 06, 2012 10:01 am Up
Just fitted a Pioneer 6400BT with Stalk adapter into a 2003 Quicksliver. On the MFD (1Line type) when the display shows Left/Right/ Doors open it scrolls as normal but stops on the final scroll just showing the Letter N from the word 'OPEN'
If I press the Left hand button on the MFD this then clears the letter N & shows the Date & Time as normal
Any idea what could be causing this, was Ok before fitting the head unit.
DW & his 2004 Red 206 GTi 180
PostPosted: Sat Oct 06, 2012 10:03 am Up
Reboot the BSI unit correctly OR unplug the mfd for a few seconds then plug it back in.
dazw30
PostPosted: Sat Oct 06, 2012 10:15 am Up
Ok thanks will give it a try
