Latest: jackrox1992
Overall: 17186
Online Now [770]:
Visitors: 770
Today: 47799
Total: 148584297
Forums › The Car › 206 Problems › Fault Code PO309
Fault Code PO309
chuckstar34
PostPosted: Sun Oct 07, 2012 5:20 am Up
Hi Guys
Im struggling to actually find out what this code really relates to. PO309 Clutch Atuator Level High ????? Ive got a X reg D-turbo . Ive cleared it to see if it comes back but its an interesting one.
Ive done a forum search with no luck, unless ive missed it.
Can anyone help ??
Tony
Chuckster.
chuckstar34
PostPosted: Mon Oct 08, 2012 6:07 am Up
UPDATE!
After a search ive found out this might be a miss leading code. It might well be a circuit fault from the brake light switch trying to tell the ecu/cruise control( if fitted) that the brakes are being held on and not to let the engine rev and puts the engine in limp home mode. I'll put a new switch in and see what occurs.
I do have a issue relating to the rev and power so might be an easy fix. Ill put a new topic up for that issue.
Ive also been in formed a visit by a Lexia 3 unit will help me adentify the probably more accuratly. Does any one have such a unit???
Tony
Chuckster.
