Posted: Mon Oct 08, 2012 2:21 pm |
Intrested in buying a 206cc, just wonder which engine is the best to get for 206cc?
I am currently driving a 2000 1.6 8v and feel like changing it cause being hit by some driver when park on the roadside ( A bit screech from rear panel to the front door and a broken font wing mirror. Just don't feel like driving it anymore after that.
Posted: Mon Oct 08, 2012 2:25 pm |
2.0 for sure
Posted: Mon Oct 08, 2012 2:28 pm |
2 litre cars come with a higher spec. Come with the 16" wheels which aren't normally on 1.6 models.
Posted: Mon Oct 08, 2012 2:31 pm |
| Edward wrote: |
| 2 litre cars come with a higher spec. Come with the 16" wheels which aren't normally on 1.6 models. |
plus 2.0 got better gearbox etc...
with the extra weight on cc i would have though it will be very slow with the 1.6 engine.
Posted: Mon Oct 08, 2012 2:44 pm |
Is it the 138 engine in the 2.0s? making it the same sort of spec as a 138?
Posted: Mon Oct 08, 2012 2:47 pm |
same engine as the 206 gti.
Posted: Mon Oct 08, 2012 3:38 pm |
Thought so... thanks for clearing that up
Posted: Mon Oct 08, 2012 5:08 pm |
Go for the 1.6 HDI lump, diesel economy with sunshine motoring
Posted: Mon Oct 08, 2012 6:42 pm |
| MrBSI wrote: |
Go for the 1.6 HDI lump, diesel economy with sunshine motoring  |
Changed your tune slightly
Posted: Tue Oct 09, 2012 5:07 am |
Thank for the recommendations, i might go for 2.0 version.
Diesel not going to be my choice since i am only doing short trip around london. Won't have the chance to clear out the filter.
Any idea what i need to watch out for 206cc when buying it?
Posted: Tue Oct 09, 2012 5:25 am |
| kit325 wrote: |
Balls, someones done there research
Posted: Tue Oct 09, 2012 5:28 am |
| MrBSI wrote: |
| kit325 wrote: |
Balls, someones done there research  |
Jesus christ thats enough to give someone a heart attack on here.
I agree with you mr Bsi. Diesel will be my choice if i do some motorway driving once a while.
They are more economy on fuel cost and insurance. Too bad living in london won't be ideal for it cause involve lot of short trip driving.
Posted: Tue Oct 09, 2012 5:51 am |
Posted: Tue Oct 09, 2012 10:10 am |
omg...
you want a diesel convertible?
plus if you worry about mpg i can tell you that 206cc always give you worse mpg than hatch back 206 (same engine).
