Online Now [113]:
Visitors: 112
Today: 48218
Total: 117611803
Forums › The Car › 206 Talk › Please no abuse
Please no abuse
Go to page 1, 2, 3, 4  Next
206HdiGti
PostPosted: Wed Oct 10, 2012 6:37 am Up
Okay here goes…
Just as well I didn’t make a bet with you BSI.
I apologise for ignoring all advice I was given and went ahead and bought the car.
It seems people can make themselves look incredibly retarded when selling a car to the point when you believe them when they say they have no idea about cars! Unfortunately this retard was very smart as the diesel filter message didn’t come up on the test drive. It did however this morning when I filled up!
Peugeot want £300 for regen which may not work a further £850 for a complete replacement.
I have had quotes for removing the whole thing, one for £380 but that's in Manchester and another for £450 in Chelmsford, 18 miles from me.
I would have had to replace/remove it eventually as Pug said that these fail at around 80k so it would have been inevitable anyway.
I would just want a construction answer to, is there any disadvantage of having it removed?
Kind regards,
Alex
cartoonhead
PostPosted: Wed Oct 10, 2012 6:45 am Up
I found this, not sure how much help it'll be to you-
' The 'diesel filter' on your cars alarm message is a particle filter in your cars exhaust system that traps most of the diesel particles. The fluid is Eolys fluid that is automatically injected into the fuel each time you fill up.
The fluid helps the particles to burn more readily at a lower temperature.
The particle filter is meant to be changed or cleaned out at 50,000, or on later model cars 80,000 miles. The Eolys fluid is filled up at the same time so that the system works for another 50 or 80k miles.
Most garages will just change the filter which is where the £749 cost is coming from.
If you are handy you can remove the particle filter & clean it yourself with jetted water & fill the Eolys container, costs about £120 for 5l of Eolys.
Your car may just need a good run ie 20 miles up the motorway at 3000 revs & 70 mph which may clean out the filter. But if your car is one that needed the filter service at 50k it will only be a temporary fix.
Do a forum search on 'FAP' & 'Eolys' & you will get a good understanding of how the system functions'.
PostPosted: Wed Oct 10, 2012 6:47 am Up
So the 8 weeks I said on your other thread was more then a bit generous of me, its not even lasted 8 days Rolling On The Floor Laughing
206HdiGti
PostPosted: Wed Oct 10, 2012 6:48 am Up
Yeah I read that this morning thanks mate. A good run in 4th for 32 miles this morning did not clear it.
Lecktorious
PostPosted: Wed Oct 10, 2012 7:12 am Up
Trade Rating: +59
No wonder. Wouldn't listen to the advice of anyone who hasn't actually owned a DV6.
You'll have blocked the filter more. To attempt a regeneration, you need to drive in a high gear and at low revs, above 40mph.
Get the codes read before you make your next move.
'98 Nile Blue 306 GTi 6
ARRAN
PostPosted: Wed Oct 10, 2012 7:24 am Up
Absolutely brilliant!!
Quoted from your previous thread.
206HdiGti wrote:
I won't be posting them [problems] on here anyway mainly due to the fact I know if I did there would be a hostile reception and I wouldn't get any help.
Laughing Laughing
See my project here.
206HdiGti
PostPosted: Wed Oct 10, 2012 7:32 am Up
It obviously had a problem before I bought it.
Everyone makes decisions against people's advice every once in a while i'm sure everyone on here has done it, but you don't learn from mistakes until you make one.
As no one else has answered my question, perhaps you could shed light on if I remove it is there any disadvantage?
206HdiGti
Laughing Laughing
You have just proved that to be correct by not giving any help or a constructive answer to the question.
Abzynthe
PostPosted: Wed Oct 10, 2012 7:34 am Up
East Area Rep - Abzynthe
Ghosty on here removed his DPF. He had some problems with it, not sure if its fixed now or not.
206HdiGti
PostPosted: Wed Oct 10, 2012 7:35 am Up
Thanks mate - how do I get the codes read?
Big_Rich180
PostPosted: Wed Oct 10, 2012 8:07 am Up
Take it to a Peugeot dealer.
206HdiGti
PostPosted: Wed Oct 10, 2012 8:14 am Up
I'm going to see if it goes away when I drive as says above and not ragging it.
PostPosted: Wed Oct 10, 2012 8:18 am Up
What She Said
206HdiGti
PostPosted: Wed Oct 10, 2012 8:25 am Up
It's a bit of an issue as i'm not really in a situation where I can do so until after the weekend.
I'm currently working my final 2 weeks notice since handing in my resignation letter and Company have been A-holes generally and leaving work early is not going to be possible. Going to a two day Indian wedding at weekend too.
I'll see if I can take it on Monday and if it's tom-tucked I'll get it removed on Tuesday.
Page 1 of 4
