Latest: tebas93089
Overall: 17179
Online Now [63]:
Visitors: 63
Today: 41183
Total: 138514715
Forums › The Car › 206 Problems › Coolant colour
Coolant colour
Domo
PostPosted: Wed Oct 10, 2012 6:42 pm Up
My mate pointed out my coolant was very low so today i bought some antifreeze nd summer coolant. Couldnt see the coolant as it was a bit dark when poured it in when it got to where it should b i could see the colour. And it came up as a dirty brown colour. Surely this isn't normal?!
Matt
PostPosted: Wed Oct 10, 2012 7:54 pm Up
Trade Rating: +32
It's fine.
PostPosted: Wed Oct 10, 2012 9:54 pm Up
if in doubt you can always drain it and refill.
PostPosted: Thu Oct 11, 2012 12:19 am Up
What He Said
Sounds like its time for a coolant flush.
robertmarcs
PostPosted: Thu Oct 11, 2012 5:29 am Up
standard citroen/peugeot stuff is blue in colour mate. if your worried about the browny colour just drain it out and refill. usually 3 or 4 litres of concentrate coolant then top up with water.
PostPosted: Thu Oct 11, 2012 1:58 pm Up
It could be the signs of the beginning of a head gasket failure.
Empty, flush then refill and watch the level and colour for a while.
Domo
PostPosted: Thu Oct 11, 2012 5:39 pm Up
How do you empty nd flush. Probs dumb question like. If i fo empty it i have premixed coolant stuff so how much that will it take to fill? Cheers guys.
PostPosted: Thu Oct 11, 2012 5:43 pm Up
there is a thread about how to change coolant.
pre-mixed stuff is useless in this case as you can't drain the coolant from the engine block easily (a good 4-5L will stay in the block)
