Latest: tebas93089
Overall: 17179
Online Now [95]:
Visitors: 94
Today: 30056
Total: 138503684
Forums › The Car › 206 Problems › Passenger headlight not working
fosk
PostPosted: Fri Oct 12, 2012 5:41 am Up
My headlight on the passenger side isn't working.
Got a new bulb and replaced the old (which looked new and fine) and nothing, tried changing fuse 11 in the box under the bonnet and still no joy.
It does however seem to be both the bulbs under there now I've noticed.
Any suggestions? I'm guessing definitely not bulb now since its both, the side light is fine.
fosk
PostPosted: Fri Oct 12, 2012 5:46 am Up
Also, I noticed both 11 and 12 have a 10 fuse in, but the diagram on here states 12 should have 15? Why would the sides have different fuses?
52 GTI
PostPosted: Fri Oct 12, 2012 6:24 am Up
do you have a Voltmeter?If you do,turn the lights on,and check for voltage,if it shows zero reading,then you have a problem in the passenger side headlight harness,check for cracked wire,or short,also check the earth points you have behind each headlight,and make sure it's well fixed.
fosk
PostPosted: Fri Oct 12, 2012 6:42 am Up
Ignore me now, got it sorted over lunch!
52 GTI
