Latest: S2cgm
Overall: 17178
Online Now [270]:
Visitors: 269
Today: 34030
Total: 137041639
Forums › The Car › 206 Problems › Brake line spanner size
Go to page Previous  1, 2
kit325
PostPosted: Mon Oct 15, 2012 1:50 am Up
You will need FLARE nut wrench for the job, you will ending up rounding up the edge of the brake line nut and make the job more difficult if you use normal wrench for the job.
I did it once and i think you need size 10 FLARE NUT WRENCH. When you undo the bolt, try to a bit of gentle tapping on the wrench when undoing the nut.
Some thing like the item below which have more contact point compare to normal wrench:
www.ebay.co.uk/itm/DRA...231428d29e
Good luck!
kit
Page 2 of 2
