Latest: Kifi69
Overall: 17183
Online Now [329]:
Visitors: 328
Today: 127448
Total: 143545074
Forums › The Car › 206 Problems › 206 Sort of a crunching noise from Rear..
NayNay1991x
PostPosted: Sun Oct 21, 2012 11:41 am Up
Hey ladies and gents, just thought i'd ask as google isnt helping much too my problem.. basically when I have 2 People in the Car I hear no crunching sound coming from the Rear but when I have say 1 or even 2 People in the back there's a crunching noise.. seems to be that it only happens when there's more weight on the rear? Any ideas cheers
206 1.4 GLX 1999 (T Reg) 3 Door
Nathen.
iainlovatt
PostPosted: Sun Oct 21, 2012 11:54 am Up
someone eating kellogs crunchy nut corn flakes
(My Garage)
iainlovatt
PostPosted: Sun Oct 21, 2012 11:55 am Up
in all honesty, sounds like a suspension problem, have you jacked it up and had a look?
(My Garage)
NayNay1991x
PostPosted: Sun Oct 21, 2012 11:58 am Up
"Theree Nutty!!" hahahaa
Its been jacked up a few times but only for different reasons what should I be looking for?
hopefully not a suspension problem im already getting the whole front done due to a leaking shock! bloody hell Sad (Touches wood)
DeeTurbo
PostPosted: Sun Oct 21, 2012 12:23 pm Up
If it's the trailing arm bearings then have a look from behind at the rear wheels and if one or both are leaning in at the top slightly it'll be them.
Not the best pic but you can see it slightly.
PostPosted: Sun Oct 21, 2012 12:44 pm Up
I think my wheel is leaning in, what do i win?
DeeTurbo
PostPosted: Sun Oct 21, 2012 12:51 pm Up
Haha, have you had your trailing arms/hubs machined for camber?
PostPosted: Sun Oct 21, 2012 1:16 pm Up
Nope Wink
Just one of my little custom mods
Spotfist
PostPosted: Sat Nov 29, 2014 6:58 pm Up
Hey guys, I noticed the other day that the wheels on my 206 lean in slightly. I didn't really think much of it as I don't hear any banging noises coming from the back. The car is fairly noisy driving over bumps with the parcel shelf moving and the boot rattle but no load bangs or anything like that.
I took a picture to see what you guys think? I can't jack the car up at the moment due to not having a driveway but plan to have a look tomorrow to try and trace a squeaking sound from the front and see if I can get a pic of both wheels.
Here is the pic.
PostPosted: Sun Nov 30, 2014 4:36 pm Up
If they are leaning in, more than likely the rear axle bearings have failed
Spotfist
PostPosted: Mon Dec 01, 2014 1:47 pm Up
Cheers for that Addaz, I don't have any crunch or bang noise as per the OP. Looking at the photo the wheels don't lean in too much. Do you think it looks bad?
PostPosted: Mon Dec 01, 2014 6:06 pm Up
From your photo, yes. It doesn't look healthy put it that way
I advise you check for play soon
PostPosted: Mon Dec 01, 2014 8:41 pm Up
It would be easier if the photo was taken from almost directly behind the car. At that angle it is quite difficult to see the angle.
Spotfist
PostPosted: Wed Dec 17, 2014 5:12 pm Up
just an update on mu situation, both wheels lean in a tad only slightly mind. There is however a little play on the right back, which is the wheel shown in the picture and has the most lean. Also turns out that the previous owner hit something as the alloy is damaged. I put on a new tyre today so as to avoid any blow outs it was that bad! Next I plan to try and fix the alloy if possible and then get the axle sorted.
lip_88
PostPosted: Thu Dec 18, 2014 3:51 am Up
I had this on a previous 206 my axle wasn't showing signs of failure so I got the bearings when I stripped it apart the shaft was nackered so just ended up using IMAXLES for a refurbed one think there around 200 quid now on an exchange basis they send a courier out to collect your old axle once you've got it swapped over
