Posted: Mon Oct 22, 2012 1:49 am |
The key remote that is used to open the doors is not working. Even the red light in the button stopped flashing or lighting. I replaced the battery, but no hope.
I just like opening the doors using the remote!.
Car is 2000 model, 1.4 8v.
What could the problem be?
Thanks.
Posted: Mon Oct 22, 2012 2:36 am |
could be the board! car still runs ye?
Posted: Mon Oct 22, 2012 2:38 am |
If you replaced the fob battery and the fob light still isn't working then you either
put in a bad battery ( check voltage)
inserted the battery incorrectly or it's not making contact ( try again)
fob button is bad- check it out
or the fob circuit board is bad
Posted: Mon Oct 22, 2012 3:23 am |
iainlovatt wrote: |
could be the board! car still runs ye? |
No problem with the car. The problem is in the key! opening and closing the door with the button is no longer working.
Posted: Mon Oct 22, 2012 3:42 am |
So it means its the board, look through the how to and see if you can re programme it?
Posted: Mon Oct 22, 2012 4:04 am |
iainlovatt wrote: |
So it means its the board, look through the how to and see if you can re programme it? |
I know how to re programme, but it didn't work.
The red led is not even flashing or making an indication that the key is working.
Posted: Mon Oct 22, 2012 5:05 am |
Deckchair5 wrote: |
or the fob circuit board is bad |
yEP.
Posted: Mon Oct 22, 2012 5:18 am |
Deckchair5 wrote: |
I tried new battery, I checked the button, I even tried to push directly through the internal button.
Sounds the board then.
But the key was working. I just wanted to change the battery because the distance were becomming bad. After I changed the battery, nothing is working. I tried with the old battery, nothing too!.
Posted: Mon Oct 22, 2012 5:19 am |
2 options then
1) battery is in wrong, or is already dead, Most probably..
2) board is bust and you need another one which isnt cheap!!
Posted: Mon Oct 22, 2012 5:47 am |
iainlovatt wrote: |
2 options then
2) board is bust and you need another one which isnt cheap!! |
If the board I'm lost.
And thanks all for the advises.
Posted: Mon Oct 22, 2012 7:45 am |
iainlovatt wrote: |
No further production, once Peugeot's stock is all used up thats it for non plexed remote keyfobs
Posted: Mon Oct 22, 2012 8:05 am |
MrBSI wrote: |
iainlovatt wrote: |
No further production, once Peugeot's stock is all used up thats it for non plexed remote keyfobs  |
Thanks for the info dude!.
