Latest: Beduff1977
Overall: 17134
Online Now [1079]:
Visitors: 1078
Today: 199073
Total: 110053496
Forums › The Car › 206 Problems › Interminent wipers not working [SOLVED]
PostPosted: Tue Oct 23, 2012 9:52 am Up
Recently replaced BSI/ECU set + key.
Works fine in all respects apart from interminent windscreen wiper mode not functioning. Any ideas why?
Looking at SB it seems the donor car had a different stalk for wipers, could this be the reason?
Also, trying to sort-out a spare key at some point; are there two different boards
for the old two-button keyfob (+dreadlocking)?
Does it use ID46 or ID45 transponder?
Cheers. Smile
PostPosted: Tue Oct 23, 2012 10:08 am Up
Intermittent wipers might need activating in the BSI or even a BSI update to allow that function to work.
Rob2859
The functions will be turned off on the BSI. Peugeot planned is needed for this. Lee re-configured mine when I swapped my ECU & BSI.
There is at least two different boards. As long as you have one fob I wouldn't bother unless you share the car regularly. Just get a blank key cut for next to nothing. The locking board and transponder for the immobiliser are separate if you didn't know.
PostPosted: Tue Oct 23, 2012 11:19 am Up
Is this the case with the old 2-button fob though?
Also, one functioning key is not good because if it's lost, then car is imobile.
I have enough cut blades already. Smile
PostPosted: Tue Oct 23, 2012 4:24 pm Up
The remote fob type depends on if the car has factory fitted front fog lamps Wink
Maybe the BSI configuration set up needs tweaking for the wipers with Peugeot Planet.
PostPosted: Wed Oct 24, 2012 3:21 am Up
I'm not tweeking anything with the clone but I'll have a read and see what's there.
Can't imagine any model 206 not having interminent mode for wipers though, unless it has to do with rain-sensor.
PostPosted: Fri Oct 26, 2012 4:19 pm Up
Yep.
Rainsensor fitted to the previous (donor) car looking at configs in PP2000.
Alarm was also fitted. Hmm...
