Posted: Tue Oct 23, 2012 9:52 am |
Recently replaced BSI/ECU set + key.
Works fine in all respects apart from interminent windscreen wiper mode not functioning. Any ideas why?
Looking at SB it seems the donor car had a different stalk for wipers, could this be the reason?
Also, trying to sort-out a spare key at some point; are there two different boards
for the old two-button keyfob (+dreadlocking)?
Does it use ID46 or ID45 transponder?
Cheers.
Posted: Tue Oct 23, 2012 10:08 am |
Intermittent wipers might need activating in the BSI or even a BSI update to allow that function to work.
The functions will be turned off on the BSI. Peugeot planned is needed for this. Lee re-configured mine when I swapped my ECU & BSI.
There is at least two different boards. As long as you have one fob I wouldn't bother unless you share the car regularly. Just get a blank key cut for next to nothing. The locking board and transponder for the immobiliser are separate if you didn't know.
Posted: Tue Oct 23, 2012 11:19 am |
Rob2859 wrote: |
There is at least two different boards. As long as you have one fob I wouldn't bother unless you share the car regularly. Just get a blank key cut for next to nothing. The locking board and transponder for the immobiliser are separate if you didn't know. |
Is this the case with the old 2-button fob though?
Also, one functioning key is not good because if it's lost, then car is imobile.
I have enough cut blades already.
Posted: Tue Oct 23, 2012 4:24 pm |
The remote fob type depends on if the car has factory fitted front fog lamps
Maybe the BSI configuration set up needs tweaking for the wipers with Peugeot Planet.
Posted: Wed Oct 24, 2012 3:21 am |
I'm not tweeking anything with the clone but I'll have a read and see what's there.
Can't imagine any model 206 not having interminent mode for wipers though, unless it has to do with rain-sensor.
Posted: Fri Oct 26, 2012 4:19 pm |
Yep.
Rainsensor fitted to the previous (donor) car looking at configs in PP2000.
Alarm was also fitted. Hmm...
