Latest: Kifi69
Overall: 17183
Online Now [294]:
Visitors: 293
Today: 29885
Total: 144176949
Forums › The Car › 206 Problems › Deadlocking retrofit
PostPosted: Wed Oct 24, 2012 4:05 am Up
'Fitted a replacement BSI with old 2-button key (UK).
What would be needed to take advantage of the second button for dead-locking?
As I recall there is one wire chopped on the connector (lock-side) even though the loom
doesn't have a line for it as is. So locks might be deadlocking already.
Both relays (normal & deadlocking) click fine with key.
PostPosted: Wed Oct 24, 2012 4:07 am Up
You would need the deadlocking door lock motors ( there's no deadlock on the tailgate )
Pretty sure its SUPERLOCKING in the BSI configuration you need as well.
No idea on the wiring, I dont do non plexed 206 Laughing
PostPosted: Wed Oct 24, 2012 4:09 am Up
Donor car had deadlocking already and I have a feeling my locks fitted at the moment are DL, just not connected on that wire.
Both rellays click fine for normal and DL modes in the BSI.
PostPosted: Wed Oct 24, 2012 4:13 am Up
The deadlock door locks normally have a bulge sticking out at the bottom of the unit where the 2nd motor is located.
PostPosted: Wed Oct 24, 2012 4:22 am Up
I have the wiring diagram if it's needed. Looks like 5 wires on the non deadlocking motor compared to 8 on the deadlocking one
PostPosted: Wed Oct 24, 2012 4:26 am Up
I've just dug out my non plexed Peugeot wiring info books Laughing
As V9977 is a decent forum members I can actually be bothered to try & help him out Wink
PostPosted: Wed Oct 24, 2012 5:29 am Up
Great, thanks.
My aim is to add another line from BSI to the locks and change lock mechanisms if needed.
@macca, changed locks on the 'other' 206 and it was 5-pin DL ones I used.
Rear doors are permenantely DL on that one now, only when locked.
PostPosted: Wed Oct 24, 2012 5:32 am Up
You got the wiring diagram OR do I need to fire up the scanner? Laughing
PostPosted: Wed Oct 24, 2012 5:41 am Up
I don't have diagram that includes DL wiring.
PostPosted: Wed Oct 24, 2012 5:42 am Up
Ill fire up the scanner then Wink
PostPosted: Wed Oct 24, 2012 5:48 am Up
Thanks, then I'll see if I manage to get locked-out of the car messing with all this. Smile
PostPosted: Wed Oct 24, 2012 5:52 am Up
PM sent, just leave the window open while you test deadlocking out Laughing
PostPosted: Wed Oct 24, 2012 5:53 am Up
Already in your inbox
PostPosted: Wed Oct 24, 2012 6:44 am Up
Brilliant, thankyou gents.
Macca you're right, 9-pin for front locks and 5 pin for rear ones it is.
