Latest: sparrowdclxvi
Overall: 17139
Online Now [136]:
Visitors: 135
Today: 33571
Total: 113481660
Forums › The Car › 206 Problems › Brake advice please
Brake advice please
Tolkienfan001
PostPosted: Thu Oct 25, 2012 1:59 pm Up
Trade Rating: +13
Hi,
Can someone with mor experience please advise me where is the best place to get the following for my 2005 1.4 16v sport 206:
. New brake discs and pads for the front ( what upgrade options are there?)
. Red brake calipers. I know I could paint them but would rather buy red ones
. Conversion for rear drums to disc brakes (is this worth it, or should I paint the drums?)
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Thu Oct 25, 2012 2:18 pm Up
Red brake calipers? That means buy Brembos etc. About £1k!
Just go to Euro Car Parts. Most of the time they are doing 30% discounts. Just paint the drums black. You dont want to highlight them by painting them red!
Tolkienfan001
PostPosted: Thu Oct 25, 2012 2:24 pm Up
Trade Rating: +13
Black is a good idea didn't think of that thanks!
2005 1.4 16v Sport
Tolkienfan001
PostPosted: Thu Oct 25, 2012 2:45 pm Up
Trade Rating: +13
What paint / primer should I use?
2005 1.4 16v Sport
DeeTurbo
PostPosted: Thu Oct 25, 2012 2:58 pm Up
I just used black hammerite on the drums of my girlfriends and I used red hammerite on my calipers but proper caliper paint is only £7.49 from Eurocarparts
Get all the rust and crud off before painting to get a good result.
If you want discs on the back you will have to change the whole rear axle and you'll have to make sure you get the one with the right type of ABS sensors.
Tolkienfan001
PostPosted: Thu Oct 25, 2012 3:06 pm Up
Trade Rating: +13
Hmmm sounds expensive!
Think I will paint drums black. Calipers red. Then just need to replace discs and pads as they have about had it.
What should I get std or better?
2005 1.4 16v Sport
PostPosted: Fri Oct 26, 2012 2:05 am Up
Just get standard stuff of a decent brand. Pagids are fine.
DeadEyePaul
PostPosted: Fri Oct 26, 2012 2:23 am Up
Mintex brakes normally do a good deal on discs + pads they are on eBay.
My engine used to be the same as yours and I have the same set up. Drums at rear (painted black). And red calipers. If your replacing the pads anyway you might as well paint the calipers whilst your there
Tolkienfan001
PostPosted: Fri Oct 26, 2012 3:02 am Up
Trade Rating: +13
Thanks Guys I apreciate the advice I will deffinately look in these brands.
DEP I will probably pant the calipers while changing brakes ETC.
I take it brake cleaner and a wire brush is ok for cleaning the drums and calipers? Then do i need a primer? or can I just paint with Hammerite?
2005 1.4 16v Sport
DeadEyePaul
PostPosted: Fri Oct 26, 2012 3:19 am Up
Brake cleaner and a wire brush and hammerite high temp paint is fine!
Tolkienfan001
PostPosted: Fri Oct 26, 2012 3:30 am Up
Trade Rating: +13
Thanks better go do some shopping and get scrubbing and painting Smile
2005 1.4 16v Sport
Sim
PostPosted: Fri Oct 26, 2012 8:31 am Up
Identify precisely the type of brake system you have. I can't afford making same mistake again Smile
Best measurement blueprints to choose from are www.brakesint.co.uk (make sure you have Adobe Flash on your computer to shop around) and they do next-day delivery as well. Used their services, and ended up having nice brembo disks shipped with Mintex pads, can't complain (note you might get other manuf.)!
Cheers,
Daily Red GTi 180, year 2004 (VorTechS' sEXy Beast (being) remasteRed)
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
