Latest: tebas93089
Overall: 17179
Online Now [118]:
Visitors: 117
Today: 35126
Total: 138088242
Forums › The Car › 206 Problems › ABS Light will not go out
davesbarratt
PostPosted: Sat Oct 27, 2012 9:14 am Up
Hi there. Have a 2002 16v 1.6 special edition. Abs light came on and when i plugged in diagnostics "wheel speed sensor circuit rear right" came up. I have replaced the sensor and code still is stored and light is still on dash. Please help. MOT due next month
richpowell91
PostPosted: Sat Oct 27, 2012 9:38 am Up
Have you had the code cleared/ checked to make sure that you are getting a reading from the new sensor?
davesbarratt
PostPosted: Sat Oct 27, 2012 11:30 am Up
Yes mate cleared the codes. Still the same problem but cannot get live data to test new sensor. Could i try standard ohmeter across sensor?
Sim
PostPosted: Sat Oct 27, 2012 12:04 pm Up
Just checking: do you drive the car around on all fours after fiddling with ABS sensors in any way?
The light never goes off until I give car a spin (3-5 minutes of driving), so the ABS system calibrates itself
Cheers,
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
davesbarratt
PostPosted: Sat Oct 27, 2012 12:26 pm Up
Well i have drove the car half a mile down the road and back and light is still on so problem still exists
PostPosted: Sat Oct 27, 2012 12:52 pm Up
What diagnostic software/equipment did your mate use to read and clear the codes?
davesbarratt
PostPosted: Sat Oct 27, 2012 12:58 pm Up
I used snap on modis. Software 11.4
PostPosted: Sat Oct 27, 2012 1:04 pm Up
Try using Peugeot Planet as that is designed for reading ABS faults. Most EOBD readers won't read/clear ABS or airbag faults.
PostPosted: Sat Oct 27, 2012 1:08 pm Up
not snap on modis though.... Rolling Eyes
PostPosted: Sat Oct 27, 2012 1:12 pm Up
Another all the gear & no idea thread springs to mind Wink
Its pointless using diagnostic equipment when you dont know how to use it correcty.
The idiot mobile mechanic on Watchdog this week is prime example of this.
davesbarratt
PostPosted: Sat Oct 27, 2012 1:18 pm Up
Well i would have thought it could clear it as it read it ok and gave me a fault code and description. Confused haha
PostPosted: Sat Oct 27, 2012 1:19 pm Up
He was a corker or should that be porker Laughing
Imagine the jack he would need to lift a car high enough to crawl under it. If the woman with the mini had called me, I'd have done the job for free, and given the car a wash and wax in the process.
davesbarratt
PostPosted: Sat Oct 27, 2012 1:20 pm Up
I can you use it better than you old man
PostPosted: Sat Oct 27, 2012 1:49 pm Up
He was a proper fat b*****d though.
PostPosted: Sun Oct 28, 2012 5:34 am Up
Reminds me of this, the kid at the end cracks me up Laughing
www.youtube.com/watch?v=QHa_SQB8NB0
Series 3 opening was pretty good to.
www.youtube.com/watch?v=vsHO7-A75QI
