Latest: jackrox1992
Overall: 17186
Online Now [584]:
Visitors: 583
Today: 86686
Total: 147810230
Forums › The Car › 206 Problems › Judder when pulling away
A10PSW
PostPosted: Thu Oct 25, 2012 3:46 pm Up
My car made a terrible judder this morning when I pulled away in 1st gear.
It seems to disappear once the engine has warmed up.
Is this the clutch on the way out? Sad
Gazza
PostPosted: Thu Oct 25, 2012 6:00 pm Up
possible but its not likely to just go on you, see what its like in the morning
Tripple P\'s......PURE PUG POWER
A10PSW
PostPosted: Fri Oct 26, 2012 8:53 am Up
Well it was ok this morning.
I am sure that the clutch is on its way out soon though as the car has done nearly 60K and it has never been replaced.
I don't know how long a clutch last but its got to be due soon surely!
PostPosted: Fri Oct 26, 2012 9:37 am Up
I wouldn't worry about it. The clutch on our 207CC is always like this from cold. The rest of the time it's perfect and it's only done 29k miles.
A10PSW
PostPosted: Fri Oct 26, 2012 9:42 am Up
29k its done 60K!
PostPosted: Fri Oct 26, 2012 9:44 am Up
60K is nothing to clutch, still got loads of meat left when i change the clutch around 75K
Quarmbo
PostPosted: Fri Oct 26, 2012 10:26 am Up
My brothers car has done 129k and has never had the clutch replaced. Depends how you drive it.
Ford SportGay-A
A10PSW
PostPosted: Fri Oct 26, 2012 10:31 am Up
129K Wow, I will see how much longer I can get away with it on mine!
Tolkienfan001
PostPosted: Fri Oct 26, 2012 10:37 am Up
Trade Rating: +13
My Astra (just been scrapped) was 148k with original clutch and had only just had the original battery replaced. Had not been serviced for 6 years! Sometimes cars have few issues in these areas.
2005 1.4 16v Sport
Check out my 206 here!
kippo2012
PostPosted: Wed Oct 31, 2012 5:33 pm Up
I had a similar thing a little while back, turned out to be the clutch slipping which meant an expensive trip to the garage for a new clutch. Does yours slip in any other gear, or just the judder in first?
A10PSW
PostPosted: Thu Nov 01, 2012 2:20 am Up
It juddered when I pulled away.
But if I am careful with the clutch it does'not do it!
kippo2012
PostPosted: Thu Nov 01, 2012 12:18 pm Up
That's what mine started out like, then over a few weeks it got worse to the point where it'd slip out of gear as I was driving along.. Which was quite annoying
ARRAN
PostPosted: Thu Nov 01, 2012 1:24 pm Up
Also how both my gearboxes started. Laughing
See my project here.
PostPosted: Thu Feb 07, 2013 3:55 pm Up
A clutch can be anything between 40k and 200k depending on your driving style (aggressive or sympathetic) and whether you do mainly motorway or short town driving in traffic.
TheGTIlad
PostPosted: Thu Feb 07, 2013 4:06 pm Up
It all depends how high the clutch bite on the pedal is, if its quite near the top, I would think about changing the clutch. If its not, I'd keep an eye on the judder to make sure it doesnt get worse.
