Forums › The Car › 206 Talk › Strut Brace Pics Wanted?? :) |
Posted: Sat Nov 03, 2012 10:43 am |
Cheers Dude =]
Posted: Sat Nov 03, 2012 12:03 pm |
and some people do make a complete mess when cutting the hole in the air scoop.
Posted: Sat Nov 03, 2012 12:09 pm |
Edward wrote: |
and some people do make a complete mess when cutting the hole in the air scoop. |
Agree'd seen some mahossive messy jobs lol
Mine wasn't much bigger than the bar itself drilled with a cutting drill bit.
Something like this from memory;
