Latest: Beduff1977
Overall: 17134
Online Now [1473]:
Visitors: 1472
Today: 17098
Total: 107677378
Forums › The Car › 206 Talk › door light fuse anyone??
karimali831
PostPosted: Thu Nov 01, 2012 11:58 am Up
Hi can anyone point me out (if there a fuse), not specified in the manual - fuse for the door lights when you open/unlock the doors and light on the hazard switch when the doors are locked which both just stopped working together. I know fuse 22 is for the courtesy light but this works fine, door light does not.
Thanks for any help.
206 GTI 180
karimali831
PostPosted: Sat Nov 03, 2012 11:22 am Up
Bump
Still the alarm light and door light not coming on.. Nothing has changed since they last worked. Pp2000 says interior courtesy light short circuit to earth but this still works fine. Sad
206 GTI 180
PostPosted: Sat Nov 03, 2012 11:41 am Up
I'd be looking to see if any recent electrical work carried out was causing the problem.
karimali831
PostPosted: Sat Nov 03, 2012 1:42 pm Up
About a week ago I removed HID kit with the crystal lights which interfered with the ECU so I replaced it with DRL headlights (plug and play) without any problems. Other than this nothing else. It was working with the DRL before. Any ideas where I should be looking?
206 GTI 180
karimali831
PostPosted: Sun Nov 04, 2012 4:38 pm Up
Last bump, sorry.
Surprised this problem is not on the internet, BSI no longer wants to play ball.. there is nothing wrong with the wiring also as I've checked again and again. I'm thinking of contacting Dealer if anyone has got any other suggestions??
206 GTI 180
