Online Now [277]:
Visitors: 276
Today: 16281
Total: 105993419
Forums › The Car › 206 Problems › Poor 2.0 HDi diesel starting problem
jcrtd51
PostPosted: Wed Nov 07, 2012 12:32 pm Up
Has anyone had problems with valve clearances on a 2.0L diesel after 125000 miles. Just wondered if poor mixture could be a reason for poor cold (frosty!) starting.
Thanks in anticipation
John
206man
cosmicdance
PostPosted: Wed Nov 07, 2012 12:37 pm Up
Now that the mornings are very cold my glow plugs come on when starting.
Are yours coming on?
Andy
Andy
jcrtd51
PostPosted: Wed Nov 07, 2012 12:38 pm Up
I fitted new ones but the old ones were working ok. I check them after removal.
John
206man
PostPosted: Wed Nov 07, 2012 12:40 pm Up
check battery.
mine won't start last week (i rarely use the car btw), it keep crank over (over mins) but never fire.
took the battery off, hook it up to the charger, next day the car just start easily.
jcrtd51
PostPosted: Wed Nov 07, 2012 1:10 pm Up
Had a new battery last year. Had the same problem last year so got a new Varta battery (but no different) and struggled over the winter but I am anticipating getting a bit fed up particularly if it is colder than last winter.
John
206man
PostPosted: Wed Nov 07, 2012 1:27 pm Up
well i don't think you can alter the valve clearances as it got hydraulic lifters which are self adjusted.
PostPosted: Wed Nov 07, 2012 6:07 pm Up
Are you waiting for the pre-heater light to extinguish before cranking the engine?
I am not an expert on the 206 diesel but most diesels have a glow plug heater light. If the weather is cold you usually turn the ignition on and then wait for the glow plug light to extinguish. if you spin it over without doing that the car is sucking air that is so cold it is difficult to ignite the air / fuel mix.
Is the 206 the same as most other diesels in this respect?
chuckstar34
PostPosted: Wed Nov 07, 2012 7:35 pm Up
Ive only ever seen my preheat light come on once...during the very cold spell year or so go. Never has a probably starting even when its that cold....minus wot ever it was. Is not seeing the light a good or bad thing???
Chuckster.
chuckstar34
PostPosted: Wed Nov 07, 2012 7:36 pm Up
Chuckster.
cosmicdance
PostPosted: Thu Nov 08, 2012 12:36 am Up
Also try pumping the fuel primer before you start it. If it starts OK after pumping then there will be air in the fuel line somewhere.
Andy
Andy
DREWDEN
PostPosted: Thu Nov 08, 2012 8:55 am Up
Glow plug lights come on when coolant temperature drops below 20 degrees celcius, (haynes manuel) it sugests to me pre post relay unit, behind battery, (attached to casing) could be the fault, had trouble with mine 2 years ago, been fine since.
Worth checking anyway. Laughing
206 2ltr Hdi glx 53 plate
jcrtd51
PostPosted: Thu Nov 08, 2012 12:48 pm Up
Thanks again for the info.
Although the tappets are hydraulic I assume it has shims that are not correct after 125000 miles b ut since no one seems to have that trouble perhaps I should look elseware.
The glow plug light does come on and I wait for it to go off, sometimes get it to come on and go off 2 or 3 times. Will check the per/post relay.
John
206man
DeeTurbo
PostPosted: Fri Nov 09, 2012 8:07 am Up
Our 206 HDI has done 117k miles and that's running sweet and I've done 297k miles in my 306 HDI.
The only problem I've had with starting on my 306 HDI was a dodgy injector. On cold winter mornings it would run lumpy but once warm would run ok. That was after 250k miles and after changing the set of injectors one fuel pipe was slightly leaking so caused it to not start on the first attempt sometimes. After sorting the leak it's been fine since.
It might be worth seeing what the fuel rail pressure is when cranking. I think if its less then 300bar it'll be a pressure issue.
