Latest: S2cgm
Overall: 17178
Online Now [92]:
Visitors: 91
Today: 52719
Total: 137060191
Forums › The Car › 206 Problems › Key programming help, please...
will-sussex
PostPosted: Fri Nov 09, 2012 6:36 am Up
Anyone know what peugeot part numbers correspond to what circuitboard numbers? trying to find out which board i need for my 2005 206 as i lost my original fob and only have the non-remote key. i bought a used 73373067B but it doesn't seem to want to communicate with my car.
All i remember about the orignal fob is it had the number[30] stamped on one side of the board. I don't suppose anyone knows what board that would be?
206SW 1.4HDI
iainlovatt
PostPosted: Fri Nov 09, 2012 7:20 am Up
Nope. Its a right pain the a**e. I bought an identical one number wise and cant get it to work. Its just a guessing game with the circuit boards,, Sad
(My Garage)
PostPosted: Fri Nov 09, 2012 7:24 am Up
Just go to a Peugeot main dealer with proof of ownership for the car, your photo id & purchase a new keyfob.
Where ever you get the fob from your going to need Peugeot Planet & the car's 4 digit alphanumeric security code to allow coding of the keys.
will-sussex
PostPosted: Mon Nov 12, 2012 7:14 am Up
i have peugeot planet, and the 4 digit code, but cant justify the expense of a new key from peugeot so im looking at used.
i was aware i needed PP and code to program a new transponder chip but didnt think you needed it to introduce a new remote fob board.
206SW 1.4HDI
PostPosted: Mon Nov 12, 2012 7:39 am Up
there is at least 4 type of remote fob on plexed 206.
and i believe they aren't interchangeable
will-sussex
PostPosted: Sat Nov 17, 2012 3:52 pm Up
yes i had heard that but we need to find out what part number corresponds to which board then everyone can find out what is the right board for their car.
206SW 1.4HDI
PostPosted: Sat Nov 17, 2012 4:11 pm Up
Just enter your chassis number on servicebox and it will tell you which remote the car was supplied with and you can't fail to get the right one.
6554 YL - EXCEPT REMOTE CONTROL WITH IMPROVED RANGE ASSEMBLY EXCEPT FRONT FOG LIGHTS LABEL "T1" OR INSERT BLUE (£67.14)
6554 YQ - REMOTE CONTROL WITH IMPROVED RANGE ASSEMBLY EXCEPT FRONT FOG LIGHTS (£57.31)
6554 YR - FRONT FOG LIGHTS EXCEPT REMOTE CONTROL WITH IMPROVED RANGE ASSEMBLY
LABEL "T1B" OR INSERT GREEN (£67.15)
6554 YV - REMOTE CONTROL WITH IMPROVED RANGE ASSEMBLY AND FRONT FOG LIGHTS (£57.31)
My 2003 is the YQ, my 2006 is the YV. Anyone with a 2004, 2005 could possibly narrow it down to when the change to the improved range was.
will-sussex
PostPosted: Sat Nov 17, 2012 4:30 pm Up
thanks but none of those numbers correspond to any numbers on the 2 boards i have tried. i will check to see what peugeot planet says about it
206SW 1.4HDI
PostPosted: Sat Nov 17, 2012 4:39 pm Up
The part numbers macca1411 posted are for a complete new remote keyfob including the key blade from Peugeot.
For what a NEW fob costs from Peugeot its a total no brainer not to buy a new one Wink
will-sussex
PostPosted: Sat Nov 17, 2012 4:45 pm Up
if you saw my car you wouldn't say that Smile
206SW 1.4HDI
PostPosted: Sat Nov 17, 2012 4:54 pm Up
Just keep wasting your money on 2nd hand fobs then Wink
actionman
PostPosted: Mon Nov 19, 2012 4:39 pm Up
there's 6 206 remotes depending on year of car, if it has front fogs or not & also if it has alarm or not
1) 1999-01 no alarm discontinued
2) 1999-01 with alarm discontinued
3) 2002-05 with front fogs £47+vat
4) 2002-05 no front fogs £49+vat
5) 2005-07 with front fogs £37+vat
6) 2005-07 no front fogs £46+vat
I supply, cut & program keys for a living & i don't mess about with 2nd hand remotes. I get at least 10 calls per week from people that have tried to save money by buying a used remote off of ebay. Most of them buy the remote because it looks the same. The majority are VAG owners
Also all you need to test if a remote is sending is an RF/IR tester. Sealey do 1 for about £20-25
Craig
Mobile remapping using the Alientech Kess V2. mobile diagnostics, fault code reading/clearing for most cars & some vans. Mobile car key cutting & programming for most makes!
PostPosted: Mon Nov 19, 2012 4:56 pm Up
Craig
I take it that 5 and 6 on your list are the improved range fobs (6554YL & 6554YR). Handy to know when the change over occurred. Good info. Thumb Up
I would suggest you write something up as a sticky thread, but people on here will still ask the same questions, so not really worth the time or effort.
actionman
PostPosted: Mon Nov 19, 2012 5:03 pm Up
numbers 5 & 6 have part numbers 6554YV & 6554YQ
I go through the same thing on every forum i'm on, which is a fair few. Tried to get a sticky set up with part numbers & as much info as possible but never got anywhere with it. Not tried on here though
Also yes, people will still ask the same questions! lol! Laughing
PostPosted: Mon Nov 19, 2012 5:11 pm Up
That doesn't make sense then. My 2003 1.4 has the part number 6554YQ and the 2006 1.4 is 6554YV.
Page 2 of 4
