Latest: Kifi69
Overall: 17183
Online Now [458]:
Visitors: 457
Today: 46774
Total: 144506596
Forums › The Car › 206 Problems › Backbox bracket just snapped! Please help
Tolkienfan001
PostPosted: Tue Nov 13, 2012 10:39 am Up
Trade Rating: +13
Hi,
The bracket near the tail pipe has just snapped. The exhaust is still attached but swinging slightly.
I have been quoted £50.00 for a new bog standard back box. I don't really want to do this as in a few months I was planning on getting a long life or power flow system (just can't quite afford it yet).
So my question is what cowboy fix can I put in place to keep me going for a couple of months until I change the whole system?
I don't do many miles a week maybe 40 or 50 at the most.
Any help or advice would be much appreciated.
2005 1.4 16v Sport
Check out my 206 here!
L5_UKS
PostPosted: Tue Nov 13, 2012 10:50 am Up
Go to your local back street car mechanic and ask them to weld it back for you will be like £10 or if your lucky like I was they might do it for free Wink
Tolkienfan001
PostPosted: Tue Nov 13, 2012 11:02 am Up
Trade Rating: +13
Thanks for that I will look into it...
2005 1.4 16v Sport
MrZiggerz
PostPosted: Tue Nov 13, 2012 11:20 am Up
Mine was £10 just to weld the bracket back, took longer to get it on the ramp than to weld it.
Tolkienfan001
PostPosted: Tue Nov 13, 2012 12:53 pm Up
Trade Rating: +13
Can they do it even if its nearly all rust?
2005 1.4 16v Sport
paul_c
PostPosted: Tue Nov 13, 2012 12:59 pm Up
No, you can't weld rust. If its nearly all rust, then it needs replacing. If its got a bit of life left but the bit that broke is rusty, then often a welded repair can be made to stretch the life of the component out a little.
It looks like circumstances have overtaken your financial planning. If you need to continue using the car, you'll need to replace (or get welded if possible, but might not be...) the back box, either with a standard one or bring forwards buying the expensive aftermarket one.
Tolkienfan001
PostPosted: Tue Nov 13, 2012 3:00 pm Up
Trade Rating: +13
Yea I agree. I think I need to try to sort out getting new exhaust early.
2005 1.4 16v Sport
RMS-GTI
PostPosted: Fri Nov 16, 2012 10:52 am Up
On the net somewhere there is a place that did sell brackets that strap round the backbox with a hanger on. Maybe worth trying to find one of those if you can't afford your new one just yet.
However it won't solve your problem if the backbox has a hole in it
Black 03 GTI. Silver 05 GTI 180
