Latest: tebas93089
Overall: 17179
Online Now [99]:
Visitors: 98
Today: 3986
Total: 138197753
Forums › The Car › 206 Problems › GTi ABS issues
GTi ABS issues
PostPosted: Wed Nov 14, 2012 11:37 am Up
Got a fault with the GTi involving the ABS, was driving along the other morning and the light just came on with ABS fault on the MFD. Plugged PP in and it just said Front Left wheel sensor - Coherence. Not had chance to get under the car yet and check the sensor and ring.
But isn't that the sensor that drives the speedo on a multiplexed 206? As my speedo has been fine, didnt do anything when the fault came up, I did clear it and within a couple of hundred yards of going down the road it did come back up.
Any suggestions? Only other thing I can think of is would a bit of dirt on the sensor cause any issues? As the night previous I did do a fair few miles down a lot of back roads that were covered in crap and the state on the car after them is unbelievable. So could have got a bit of dirt flicked up on to the sensor.
PostPosted: Wed Nov 14, 2012 12:09 pm Up
Unless you were up to the wings on dirt, it's hard for the sensors to get dirty. You could check the ring, more than likely sensor failure, or faulty wiring. Good job you got PP to check.
bezford
PostPosted: Wed Nov 14, 2012 1:57 pm Up
Where and how much for pp/code reader?i presume they are the same that everyone uses on here?do they plug into engine diagnostic plug?
R.HYDE
Big_Rich180
PostPosted: Wed Nov 14, 2012 3:59 pm Up
When I had the 180 one of the wires broke that went to the ABS sensor, the sensor was always reading 1000MPH or similar lol
bezford
PostPosted: Wed Nov 14, 2012 4:18 pm Up
could it be an actual problem with the discs/pads/piping etc?is the abs and brakes working normaly/properly?
R.HYDE
