Latest: Kifi69
Overall: 17183
Online Now [1228]:
Visitors: 1227
Today: 46930
Total: 143464653
Forums › The Car › 206 Problems › 206 1.1 misfire
206 1.1 misfire
Drew67
PostPosted: Wed Nov 14, 2012 4:48 pm Up
Hi All,
i`ve a 206 1.1 51plate that i`ve owned a week, ran like a dream until last nite when i gave the coil pack, plugs, injectors (you get the picture) a liberal does of WD 40 type spray.
Now ive got a misfire, the EML light flashes and a fault code P0300 which i believe is Random/Multiple Engine Misfire.
I removed the plugs which are Peugeot well worn so i`m replacing those with Bosch tomorrow, should i replace the coil pack?.
After ive done this, should it still misfire what should i be looking at?
Thanks in advance for any advice its all gratefully received.
Rgds Drew.
tom206priest
PostPosted: Thu Nov 15, 2012 9:32 am Up
Hi,
You should change the plugs and see if it still misfires. Check all the connections over a loose one could cause problems. If you still have a misfire then change the coil pack.
Cheers
coopskin
PostPosted: Thu Nov 15, 2012 12:19 pm Up
Trade Rating: +13
Question..... Why did you spray the things listed above with WD40 or as like substance?
Drew67
PostPosted: Thu Nov 15, 2012 12:57 pm Up
Haha Coopskin, in answer to your question the reason I sprayed everything around the ignition with a WD40 type substance was last time I owned a petrol car they had plug leads,coils distributor caps n points, all of which used to suffer from damp in the winter months, so I thought I'd give myself a head start by spraying WD 40 on everything before the damp beat me to it
coopskin
PostPosted: Thu Nov 15, 2012 1:49 pm Up
Trade Rating: +13
Ah, that's some old style engines.....you may find that you have got some of the substance in the coil pack connector, I would disconnect it, get as much off the connector and the coil pack as possible and reconnect. See what that does..
Drew67
PostPosted: Thu Nov 15, 2012 2:59 pm Up
Hi Coopskin,
Fitted new Bosch plugs tried different coil pack and maf sensor still get error code 0300random/multiple cylinder misfire, will try to get compressed air to blow out grey connector plug and take it from there.
Thanks for your help.
Rgds Drew
Drew67
PostPosted: Thu Nov 15, 2012 4:24 pm Up
Hi All,
Tried using compressed air in the connectors to no avail,still getting a misfire and code 0300 (random/multiple engine misfire).
Going to try a new coil pack if nothing else it'll remove it from the list of possible faults.
Rgds Drew.
coopskin
PostPosted: Thu Nov 15, 2012 6:28 pm Up
Trade Rating: +13
Intriguing......maybe it was a co-incidence....?
PostPosted: Thu Nov 15, 2012 6:35 pm Up
WD40 bad.
PostPosted: Fri Nov 16, 2012 1:05 am Up
you better start off with cleaning every electric connection point with proper cleaner first.
WD40 is oily stuff which do no good to electric stuff
Drew67
PostPosted: Fri Nov 16, 2012 4:22 am Up
Hi all,
Thanks for all your help, i guess gone are the days when WD40was the way forward, i'mfeeling old lol
Drew67
PostPosted: Mon Nov 19, 2012 10:27 am Up
Hi All,
after further investigation this weekend it appears my misfire is leavng no1 plug wet with petrol so a new coil pack on its way if if that dont cure it we'll start on the wiring.
Thanks again for all your help . Drew
Drew67
PostPosted: Mon Nov 19, 2012 2:01 pm Up
Hi All
Fitted new coil pack and hey presto no difference, so ive checked voltages to plug and 3 of the 4 wires have 14 odd volts when its running but 1 the green with red tracer only has a nominal voltage, ive checked continuity back to virtually the ECU and there's no break in the wire.
So my first question is should i have voltage to the green with red tracer wire? I'm presuming so
Secondly does this mean my ECU has gone capput?
Last question how expensive is it to re-code another ECU?
Thanks again for your help. Rgds Drew
Drew67
PostPosted: Wed Nov 21, 2012 5:08 am Up
Hi All,
Fault turned out to be an Injector,1's completely goosed and anothers on its way so 2 injectors later n finally were up n running.
Thanks everyone for all your help.
Rgds Drew
