Latest: tebas93089
Overall: 17179
Online Now [70]:
Visitors: 69
Today: 2113
Total: 138521916
Forums › The Car › 206 Problems › Blue Smoke :-(
Blue Smoke :-(
rhian206
PostPosted: Mon Nov 19, 2012 4:07 am Up
Morning all,
Wondering if anyone could help me!
This morning i went out to my 206 1.6 and tried to start her up, at first it wouldnt start eventually when it started i had a cloud of blue smoke then it cut out, tried to start her again and it was turning over rapidly, and again fired up and ran roughly. Small ammount of smoke on idle.
I drove her on a 2 mile trip and she drove perfectly as she always had in the past...
Any suggestions.
Rhian Question
lmilligan
PostPosted: Mon Nov 19, 2012 4:09 am Up
iirc if blue smoke is being produced that means its burning oil
rhian206
PostPosted: Mon Nov 19, 2012 4:11 am Up
Is it a common fault burning oil on the 1.6 16v engine, and what would be the likely cause of it burning oil??
Rhian
DeadEyePaul
PostPosted: Mon Nov 19, 2012 4:15 am Up
Search engines usually provide the answer
Quarmbo
PostPosted: Mon Nov 19, 2012 4:16 am Up
Over fill? Oil leak?
Ford SportGay-A
rhian206
PostPosted: Mon Nov 19, 2012 5:29 am Up
I checked the oil and it is between min and max so cannot be overfill.
DeadEyePaul
PostPosted: Mon Nov 19, 2012 5:46 am Up
The link I provided says its the seals
Gazza
PostPosted: Mon Nov 19, 2012 6:43 am Up
valve stem seals gone, might be work trying some oil vitality addeditive, put it into the oil and its suppossed to revitalise the oils seals which i have used before and worked but if the seals are to far warn/dameged then it may not work
Tripple P\'s......PURE PUG POWER
wonkey_18
PostPosted: Mon Nov 19, 2012 7:34 am Up
how long since its had a service?
Wonkey
rhian206
PostPosted: Mon Nov 19, 2012 7:38 am Up
It last had a full service in june this year, i have since been out in the car and its cleared up.
im guessing its being burnt off as im driving so if it comes back in the morning we have a problem
wonkey_18
PostPosted: Mon Nov 19, 2012 8:27 am Up
give the car a good sensible run down the dual carridgeway for a few miles to clear it out
Wonkey
bezford
PostPosted: Mon Nov 19, 2012 11:40 am Up
Has the underside of the oil filler cap got any gunk on it and wot colour is. It?did u put fuel in it the day before it smoked?its defo oil gettin into the cylinder ....just wheres it coming in from?
R.HYDE
rhian206
PostPosted: Mon Nov 19, 2012 12:14 pm Up
Hiya
I put £20 of fuel in yesterday morning, and it was fine for the 50 miles i did then it stood for 18 hours then the problem ac cured. The oil cap looks the usual colour i have had a car before that was like mayonnaise but this is clear. I have been driving around most of the day.
I gave it a good run. So i spose the best thing to do now is see what the morning brings.
Rhian
