Latest: tbafonso
Overall: 17130
Online Now [375]:
Visitors: 374
Today: 8474
Total: 104540312
Forums › The Car › 206 Problems › Engine change
Engine change
Go to page 1, 2, 3  Next
Deano
PostPosted: Wed Nov 21, 2012 10:36 am Up
Would a engine out of a 180 go straight into a 140 with out changing ecu or bsi n stuff
Big_Rich180
PostPosted: Wed Nov 21, 2012 10:41 am Up
No.
It will fit in but it wont work.
PostPosted: Wed Nov 21, 2012 10:44 am Up
Would be easier if it's a multiplexed 140, but still wouldn't be a straight swap. If it's a pre plex 140, dont even bother thinking about it unless you have a donor car.
Deano
PostPosted: Wed Nov 21, 2012 12:06 pm Up
Does a 307 2.0 engine fit a 206 gti
PostPosted: Wed Nov 21, 2012 12:23 pm Up
Dont see why not.....
But why bother?
Deano
PostPosted: Wed Nov 21, 2012 12:41 pm Up
because my engine has seized and I can get one cheap out of a 307 would I need to change the ecu and would my original keys still work
PostPosted: Wed Nov 21, 2012 12:45 pm Up
An engine is an engine, just swap that and use all you 206 looms. You should be fine
Deano
PostPosted: Wed Nov 21, 2012 12:51 pm Up
That's what I thought I am only changing the block but could do with knowing for sure the engine looks the same out of the 307 just don't want to take the block then him get rid of donor n me be stuck with n ecu so if I just change my block nothing else it should start up fine
Deano
PostPosted: Wed Nov 21, 2012 1:10 pm Up
How do I tell if mine is multiplex or pre plex because will I have to check that the donor engine is comin out of the same
As long as you only change the mechanical part and not any of the electrics you will be fine.
rhian206
PostPosted: Wed Nov 21, 2012 1:41 pm Up
they is a 1.4 quicksilver 206 in ebay with a GTI180 engine in with nitrous oxide so anything is possible
PostPosted: Wed Nov 21, 2012 2:01 pm Up
Yes it is possible, any 206 engine can be swapped around into any other 206, it's just 9 times out of 10, it's the 17/18 year old's trying to avoid the insurance, that by the time they spend the money buying all the bits and the time & labor to do it it would have come to the same price as just buying and insuring the other car in the first place.
kobrakai1986
PostPosted: Wed Nov 21, 2012 2:18 pm Up
307 engine should be the same but you would probably need to use 206 engine mounts, I would think most 2.0 engines around the same age from any Citroën or Peugeot would be the same? If your throwing in the 180 engine you would need a 180 ecu and I'm not 100% sure but you may need few other bits for the key to work.
'02 206 Quiksilver. SP Kit. Gloss black 205 Speedlines. ICC Tuning WRC spoiler (civic style). Sparco Rally Flaps. Laguna splitter. Upper and lower front Struts. V-Maxx front coilovers and Apex rear shocks. GTI180 front Arb. GTI180 front brake set up. 4-2-1 Mani, 200cell sport cat, stainless pipes and sportex 3" rolled box. Gloss black morettes with yellow lenses. Yellow tinted fogs with yellow bulbs.
Deano
PostPosted: Wed Nov 21, 2012 2:58 pm Up
No the engine out of the 307 is 138bhp the same as my 206 I just need to know about this multiplex does the donor engine need to be the same as whatever mine is and how do I tell if mine is the same I have not changed 206 engine before can I leave the gearbox in and does Anyone know a link on changing the Cambrelt I might as well change everything why engine is out
Deano
PostPosted: Wed Nov 21, 2012 3:03 pm Up
Page 1 of 3
